Thread: U Factor
02-06-2007, 10:17 AM #1
U Factor
I have to submit a design for the air conditioning system for an operators cabin in a EOT Crane in an Alumunium Plant. The cabins are constructed of 6 mm thick mild steel plates. I am unable to locate the Transmission Coefficient U for the steel plates. Could some one help me with both the SI and IP version of the U factor for the above stated item.
Thank you.
02-06-2007, 08:06 PM #2
Re: U Factor
Hi, does this web page help at all...
http://www.engineeringtoolbox.com/ov...nts-d_284.htmlBrian - Newton Abbot, Devon, UK
03-06-2007, 03:53 AM #3
Re: U Factor
Dear Brian,
Thank you very much for the Engineering Tool Box Website. It has all the contents that I required for my design.
With best wishes,
Derating factor for ice maker using salty water
By Gonzalo Arias in forum NH3Replies: 1Last Post: 18-05-2007, 03:57 PM -
Heat Rejection Factor
By nh3simman in forum FundamentalsReplies: 18Last Post: 20-04-2007, 02:40 PM -
Unit cooler rating factor
By nh3simman in forum FundamentalsReplies: 4Last Post: 17-03-2007, 02:58 PM -
power factor correction
By marley821 in forum Technical DiscussionsReplies: 4Last Post: 06-05-2006, 08:29 PM -
Looking for "K" factor and "U" factor tables
By mayot in forum FundamentalsReplies: 1Last Post: 03-02-2006, 09:19 PM
