Results 1 to 16 of 16
    Nov 2005
    211
    Why you should not buy a cheap multimeter
    Here's a reason why you should not buy a cheap DMM. The input filter in cheap meters easily gets confused and attenuates the signal, and worse than that, the amount of attenuation is unpredictable so you have no way to know the real measurement!
    To demonstrate, I'll use a cheap meter (about $35) and an expensive meter (about $80) to measure the normal AC line.
    So far so good, right? That's because they're measuring an almost pure sine wave.
    But measure the UPS output and look what happens!
    That's because they're measuring a square wave, which confuses the input filter in the cheap meter. The expensive meter has better input filters that are not confused by high frequencies in the signal being measured.
    This inaccuracy is confusing at best and dangerous at worst. A cheap meter can easily cost you a lot in the long run!
    "If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
    Oct 2004
    Scotland
    1,454
    Re: Why you should not buy a cheap multimeter
    I wonder what the £15 one I got today would do...lol
    Good explanation of "You only get what you paid for".
    Chillin
    and go get a cuppa
    5,667
    Quite right Chillin'
    But I don't think that $80 is what you would call an "expensive model".
    I paid £126 for my Fluke ($245) so
    Aug 2005
    5,302
    Expense is one of those relative terms. My old Fluke DMM was about $600 US almost 25 years ago. I understand they are a little cheaper now!
    I would not use any meter that was in the price range described by Star882. And, I would not buy one unless it had the Fluke name on it. They build very good meters!
    Apr 2006
    1,620
    I got a circuit test that cost me 300 cad 10 or so years ago. So far it works great and messures pretty much every thing reliably and has a built in frequancy counter
    Nov 2005
    211
    It all depends on the application. The $80 one described works fine for most personal uses. But if you need NIST calibration, standalone data logging, LCR measurement functions, etc., by all means get it! Just overkill for the average user. Most amateur PC technicians get away with $10 specials. (I can't wait for one to get confused when measuring a UPS,then he calls me over and I show him that it's working correctly.)
    Jul 2006
    865
    Quote Originally Posted by star882 View Post
    Here's a reason why you should not buy a cheap !
    Star882;
    Once again you bring controversy to the forum. (I like that in a person)
    Will bring my Fluke 66 home next week and check it on my UPS's. Never have done that, I always assumed that the output was a true Sine Wave until the power failed. Perhaps I should bring my old Oscilloscope up from the basement and take a look.
    I noticed years ago that I could not measure the output of a Variable speed drive with my voltmeter. I assumed that this was because the output was not a true sine wave. Are the high peak voltages I observed real or the fault of my meter? I assumed that they were real as I soon found out that non VFD rated motors failed very quickly when connected to a VFD.
    analog's Avatar
    analog Guest
    Quote Originally Posted by NH3LVR View Post
    Star882;
    I, for one, have always used the cheapest tools available.
    Except for my lucky pen. I've had it for over 10 years. It writes pure gold. It can turn a blown transformer caused by my own stupidity into "performed low voltage circuit trace", that sentence alone has got to be worth 150 quid.
    As far as meters go, I've always relied on my second hand amprobe to tell me if a wire is hot, when in doubt, my helper James performs a "wet finger" test.
    His new pacemaker is working out nicely.
    Nov 2005
    211
    It depends on design. The UPS in the pictures is old so it outputs a square wave. A few new ones, however, output sine waves. For computer equipment, however, a lightly filtered 170v peak square wave is actually better than a 120v RMS sine wave. It does increase the chances of an EMI problem but I have never seen it actually cause system problems.
    BTW, most UPSes first rectify the incoming AC to charge up a capacitor. Then it uses a H bridge to recreate AC. A DC/DC converter provides switchover by converting 12v from the battery pack to 170v. Another DC/DC converter charges the battery from 170v. (Some UPSes use a bidirectional DC/DC converter.)
    analog's Avatar
    analog Guest
    I've always found the sine wave protocal (based on the works of Dr. Kurt Jurger) to contain to many variables when contrasted with the UPSes used today.
    Rectification of capacitance is a Tessla theory that holds no water.
    The H bridge has pretty much been replaced by the M
    jmho
    Feb 2007
    North Carolina, USA
    Fluke True RMS meters are the way to go.
    Another thing that i hate about cheap meters is the sampling rates. I hate having to wait for the display to settle in. It is like watching a cap charge up.
    Nov 2005
    New Zealand
    550
    GeeZ I must be gettin old I still swear by my old Simpson meter And my year1972 amprobe, well I been out the business for nye on 20 years suppose being senile helps I guess
    Toosh
    FrankWSmith's Avatar
    FrankWSmith Guest
    Fluke stays the best, not cheap but the best, own three models at present.
    Finland
    59
    Fluke at 250 Euros, is good but I wont trust my life on it.
    Norway
    1,042
    4
    $624
    had it for six years now... co-worker borrowed it and blew something inside, causing it to make a beep beep beep sound every now and then, it's been back to fluke, but got it back with a "No fault found, changed fuses" made the beep beep beep sound for a few months, but stopped now
    -Cheers-
    Tycho
    Aug 2008
    44
    I never leave home without these. For amps I use an ordinary clamp meter.
  1. Cheap and easy coldroom?
    By Jeremyjtthompso in forum Fundamentals
    Last Post: 25-04-2010, 09:49 PM
  2. Welcome cheap coolers!
    By WebRam in forum New to RE
    Last Post: 13-10-2005, 10:59 AM
  3. cheap imports
    By eggs in forum Legal-Business-Marketing
    Last Post: 23-11-2004, 08:18 PM
  4. Cheap PLC's
    By Peter_1 in forum Electrical
    Last Post: 08-07-2004, 10:13 PM
