    Scotland
    327
    Daikin HP and LP dropping after closing HP valve
    Called out to old Daikin Split RY125FJW1C-EO code.
    Reset unit, brought on cooling.
    Low superheat, Low LP (3 bar), Low HP (9.5 bar) R22
    6.2 amps per phase.
    Freezing up on low side outdoor unit.
    Cleaned dirty filters, no change.
    Shut HP valve to check compressor - immediately both the HP and LP dropped, re-opened valve before LP switch could open.
    Decided compressor was about to conk but now wondering if am I right. Can't think whats happened inside the compressor to cause this.
    One of two units installed 1998 in a gym running 0700-2300 every day, possibly left 24/7.
    Any comments welcome, thank you
    Sep 2005
    Singapore
    59
    145
    Re: Daikin HP and LP dropping after closing HP valve
    what is your on coil and off coil air temperature? Thermostat setting etc.
    Northants
    290
    If you mean the valves on the condensing unit, shutting the HP one will drop both pressures because its clearing the evap of refrigerant (same as a pumpdown)
    Mar 2007
    France
    236
    Sounds like indoor unit problem causing wet operation to the compressor.
    Is the indoor unit ducted or cassette type ?
    Maybe the indoor coil is dirty or the air flow's not enough.
    If you succeed in pump down why will you change comp first !
    Be careful to take hp from the inside of the outdoor unit (not from service valve)
    rgds
    cool#9
    11,025
    I would double check the evaporator coil.
    You say that it is a gym and by past experience I have found that coils in a disgusting state.
  1. Daikin not working... many problems
    By stankovicv in forum Air Conditioning
    Last Post: 11-12-2010, 09:01 AM
  2. Daikin - Closing Flaps
    By JamRichard in forum Air Conditioning
    Last Post: 22-02-2007, 08:24 PM
  3. Need a correctly sized valve
    By Abe in forum Commercial
    Last Post: 26-10-2005, 08:42 PM
  4. Replies: 5
    Last Post: 16-10-2002, 12:38 AM
  5. Valve "Hunting"
    By Abe in forum Trouble Shooting
    Last Post: 21-01-2002, 12:29 AM
