Results 1 to 12 of 12
Thread: oil level in compressor
29-05-2007, 07:32 PM #1
hi again fellas iwas wondering that when you are adding oil to a compressor ,can i go of the sight glass to say half way or not? I know there is ment to be 6.6 litres in it but say you couldnt get the rest out and its second hand any help welcome thanks alot
adam
29-05-2007, 07:36 PM #2
Re: oil level in compressor
Second hand oil? I can only say: "why?"
29-05-2007, 08:09 PM #3
If you're not sure how much has come out of the system then really you need to run on full load to get the present oil charge back.
Monitor the level with the system running and add or remove as required.Brian - Newton Abbot, Devon, UK
29-05-2007, 08:11 PM #4
hehe iknew these questions was going to come no i ment.... a second hand compressor which has run before but now been put into another unit and oil drained by some one eles. So if you imagine ihave turned up to put this compressor in but got told by the customers the other firm said they took the oil out etc etc and nothing in the sight glass i have got the oil which is the correct type but 6.6 litres is from dry.just a general question really i would of thought you should be able to go off the sight glass but you never know thanks alot
adam
29-05-2007, 08:12 PM #5
But Brian what if there is nothing in the compressor any chance of it seizing of burning out etc problems??
thanks alot adam
29-05-2007, 08:14 PM #6
No, fair comment, fill to the bottom quarter of the sight glass to start with so that there is some in there.
Have you got an oil pump so that you can add with the unit running?Brian - Newton Abbot, Devon, UK
29-05-2007, 08:20 PM #7
yer brian now do i put it in the oil port next to the sight glass or can i put it in the suction. Not to sure on this,can you put it in the suction or not and if not why not thanks alot
adam
29-05-2007, 08:37 PM #8
Bear in mind that the oil returning from the system is going into the compressor via the suction port so you can charge through there as well.
Mind you, don't pump too hardBrian - Newton Abbot, Devon, UK
29-05-2007, 08:39 PM #9
ok cool just put it in abit at a time in the suction then thanks alot brian
adam
29-05-2007, 08:55 PM #10
Just fill it up to half way across tha sight glass and it should be ok.
Run it for a while and recheck the level.
and go get a cuppa
29-05-2007, 10:00 PM #11
thanks alot fellas great help once again
29-05-2007, 11:17 PM #12
If you pump it in the suction too quickly it can get pumped round the system by the compressor insted of droping into the sump. You look at the sight glass and think job done and pack up tools etc. Do a final check after paperwork, cup of tea etc and think begger me wheres all that oil come from?
Jon
A useful article
By chemi-cool in forum New TechnologiesReplies: 5Last Post: 21-07-2007, 03:25 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM
