Thread: displacement compressors
28-05-2007, 10:30 PM #1
hi there can any one help me i have condemend a compressor being an aspera t2168gk which is 3/4 h/p and has displacement off 17 however i already have a t2178gk in stock which is also a 3/4 h/p but has a displacement off 20 i was wanting to know what displacement was and whether i would get away with fitting the compressor i already have as it would save me a small fortune can any one advise thanks james
28-05-2007, 11:23 PM #2
Re: displacement compressors
According to the compressor chart here...
https://pgw100.portal.gases.boc.com/...ompressors.asp
The T2168 is a 1/2hp rated at 752Watts while the T2178 is a 5/8hp rated at 910Watts.
The sites compressor comparision chart gives the range rating as..
T2168 701-800W
T2178 901-1000W
Don't know whether this helps or hinders but at least you've got some more numbers to worry about nowBrian - Newton Abbot, Devon, UK
29-05-2007, 08:11 PM #3
hi brian thanks for that info that helps slightly but refering to the nrs book it lists them both as the same h/p and the only diffrence between them is the displacement i think i will just buy the right compressor thanks again james
Time delay for multi compressors
By iceman007 in forum Air ConditioningReplies: 5Last Post: 06-11-2004, 09:05 AM -
Compressor's volume efficiency
By John McGru in forum FundamentalsReplies: 0Last Post: 16-02-2004, 09:44 AM
