Results 1 to 12 of 12
Thread: Brine
26-05-2007, 05:08 PM #1
Brine
What specific gravity should i have if i have a system evaporating at -35C to get brine down to -25C.
26-05-2007, 06:54 PM #2
Re: Brine
If you will be more specific on the type of brine you want to use then someone can develop an answer for you.
Another possible question might also be; Is the piping exposed to lower temperatures during shut down conditions, say winter ambient temperatures?
The operating temperature is only one point where the freezing temperature of the brine needs to be considered.If all else fails, ask for help.
26-05-2007, 08:15 PM #3
Re: Brine
Thanks!!
The salt used is Calcium chloride.
The system is a tank full of a water and calcium chloride brine mix, the mixture is circulated by a aggitator, the refrigeration evaporator is submersed in the mixture to cool it, the customer requires the mixture to be -25C
Thanks for your response
26-05-2007, 09:00 PM #4
Re: Brine
A solution of 29% calcium chloride (by mass) will provide a -45°F (-42.78°C) freezing temperature of the brine. At this solution, the specific gravity is about 1.296.
27-05-2007, 02:03 PM #5
27-05-2007, 09:33 PM #6
Re: Brine
You want a safety margin for when weird things happen that we do not expect.
27-05-2007, 11:32 PM #7
Re: Brine
The original evaporating temperature was stated to be -35C, and I always add some margin of safety to cover unexpected operating conditions.
I might be a little high on the concentration, but did so knowing very little about what you are trying to accomplish.
Insufficient information = increased safety factors.If all else fails, ask for help.
28-05-2007, 09:53 AM #8
08-07-2007, 09:06 PM #9
Re: Brine
Chilly,
Just as a matter of interest, tell me about your system. Size, application, refrigerant, etc.
Thanks, Intermez
09-07-2007, 06:14 PM #10
Re: Brine
Hi Intermez
The system is used for making ice lolly's.
A brine soultion is in a tank and is circulated over a submersed evaporator within the same tank, the brine operates at -25deg. C, system evaporates at around -32deg. C.
The refrigerant used is R404A
The condensing unit is a Maneurope MTZ160 giving a duty at -30deg. C of around 8KW condensing @ 32deg.C
Expansion valve Danfoss TES5 with a Nunmber 2 orifice cage.
suction is 1"1/8 with a 1/2 liquid line
Hope this helps
Chilly Blue
09-07-2007, 08:40 PM #11
Re: Brine
Hey chillyblue
What is your problem? UsIceman has given the answer. The manufactured lollies are not hardened enough to remove from the moulds?
Suny
11-07-2007, 08:30 PM #12
Re: Brine
Hi Suny
As you said, i do not have a problem now, it has been resolved via this forum!!!, but if you look at the previous entry by Itermez i quote you will see i was just answering his question.
"Chilly,
Thanks, Intermez
automating a chilled brine refrigeration system using ammonia refrigerant
By luciom in forum IndustrialReplies: 29Last Post: 02-10-2008, 09:48 PM -
NH3 system for minus 40 deg c brine temperature
By meg in forum NH3Replies: 17Last Post: 04-02-2008, 08:46 AM -
Can’t get a brine chiller down to temperature.
By dkemper in forum Trouble ShootingReplies: 8Last Post: 08-06-2007, 03:38 PM -
Shrimps Brine Freezing
By refac-45 in forum IndustrialReplies: 3Last Post: 12-05-2006, 08:24 PM -
Brine system.
By Temprite in forum Tools and CalculatorsReplies: 0Last Post: 16-12-2004, 09:51 AM
