Results 1 to 16 of 16
Thread: Eliwell ID974
    GVLax50's Avatar
    GVLax50 Guest
    Eliwell ID974
    I have a Eliwell ID974 controller in a used Samoa 120 gelato case. It didn't come with a manual and once or twice a day it goes into defrost mode and jumps from -17C to 8C and completely ruins my ice cream product in the case. Does anyone know where I can find a manual or can anyone tell me how to simply turn off the defrost setting so that it doesn't defrost on it's own? Thanks.
    Jan 2003
    East Anglia
    1,175
    Re: Eliwell ID974
    Having to work off memory on this on so if i am wrong i am sure someone will correct me
    Push and hold the set key, after 5 seconds it take you into the set up menu, first one being CP
    use up and down to get to the defrost menu, push set, scroll through, defrost termination temp should be DLI, Defrost interval time (Time between defrosts) is DTI
    Defrost Endurance time is DET
    Hope this helps
    Raymond
    70
    10,602
    52
    Re: Eliwell ID974
    This document has a 974 but I'm not sure if it is the same as yours, might be worth a try though.
    http://www.thermofrostcryo.co.uk/tec...ndbookv2.0.pdf
    [edit]
    Sorry, try this one, it's got the ID374
    http://www.hawco-refrigeration.co.uk/support.asp
    Oct 2004
    Scotland
    40
    1,482
    15
    Re: Eliwell ID974
    Is it hot gas defrost?
    They usually are on ice cream cases.
    Make sure the fans are not running during defrost.
    Chillin
    and go get a cuppa
    Apr 2001
    2,121
    21
    Re: Eliwell ID974
    [edit]
    Brian
    Its the ID , not IC range
    Ive also been looking with no success as yet
    Jan 2006
    54
    13
    Re: Eliwell ID974
    Download instructions from here
    http://www.frostechnic.com/service.htm
    Oct 2003
    56
    5,519
    28
    Re: Eliwell ID974
    You may not simply remove these defrosts, there's a change that your compressor will be dead within some time (liquid slugging)
    Once or twice a day isn't even that much.
    There's something else that's wrong.
    Anyhow, you have to pass 0C, otherwise the ice won't melt
    Ohhh,...and welcome. Where's PA anywhere
    BTW, in attachment your manual but again, this isn't the way you have to solve this.
    Attached Files Attached Files
    Jan 2006
    54
    13
    Re: Eliwell ID974
    PA? Pennsylvania?
    Apr 2001
    2,121
    21
    Re: Eliwell ID974
    Thank you Waldon and Peter
    Oct 2003
    56
    5,519
    28
    Re: Eliwell ID974
    The importer of Eliwell and Dixell gave me a DVD with all the manuals on it, so I never have to look very far.
    frasc7's Avatar
    frasc7 Guest
    Re: Eliwell ID974
    HI! i'M IN SPAIN AND I HAVE EXACTLY THE SAME PROBLE AS YOU HAVE WITH THE ELIWELL ID 974. DID YOU FIND A SOLUTION YET!
    THNKS
    Quote Originally Posted by GVLax50 View Post
    Oct 2003
    56
    5,519
    28
    Re: Eliwell ID974
    GVLAX50, was that all you needed?
    No problem, thanks
    Mar 2007
    canada
    37
    47
    Re: Eliwell ID974
    I have recently been working on a gelato case that has two evaporators and is hot gas defrost. The defrosts are staggered on each evap to try to maintain the case temperature ( and supply a heat load). It also uses the same type of controller and it has multiple defrost outputs for HGV.
    Gelato is not that common in canada, this is the first case I have seen, it is made by IFI from Italy. Model: tug160a
    Is this type of hot gas set up common on gelato displays?
    Sorry, the actual controller I have is a xw746k, the ID974 may not have the same functions.
    Jun 2007
    azores islands
    11
    Re: Eliwell ID974
    I have the ID974 manual. Give me your mail, and i will send it to you.
    Italy
    15
    Re: Eliwell ID974
    Hi All,
    the manual of eliwell Id 974 is downloadable from the invensys web site @eliwell.it
    Electronic refrigeration controller \ digifrost line
    Eliwell has also a rappresentative in Slough (UK) with a technical support.
    Here's the link to dowload the manual. Hope this help otherwise give me your mail, i'll very please to send the manual.
    Italy
    15
    Re: Eliwell ID974
    Hi All,
    I think it's enough to act on DST paramenter if the evaporator probe is present. If reduced defrost will end at a lower temperature.
    Dt has effect as well, because has effect on compressor activation delay after defrosting. it's needed for the drainage
  1. Eliwell amp controller EV782
    By alan thompson in forum Commercial
    Last Post: 28-02-2007, 06:06 PM
  2. Eliwell Ewpc 961
    By KCDOMAPPS in forum Commercial
    Last Post: 26-02-2007, 06:57 PM
  3. Eliwell ECH 210
    By chemi-cool in forum Trouble Shooting
    Last Post: 03-09-2006, 12:51 PM
