Threaded View
05-03-2008, 10:19 PM #8
Re: Compressor loading, cooling, and range of operation.
Most consideration are too general to be applied to real cases. For example, a low temperature compressor can be used for high temperature, provided superheat is kept low enough to boil it off.
Also: the rotor can be modified on the fly to accomodate a wider or narrower rotating disk and cool the motor at the expense of discharge temperature.
So, I do not agree with you 100%.
Also please note that low, medium or high temperature is not a feature of Embraco, but it is decided by european norm EN12900.
Cooling tower evaporation, blowdown, makeup and cycles
By miltbeychok in forum IndustrialReplies: 5Last Post: 14-10-2005, 06:34 PM -
By miltbeychok in forum FundamentalsReplies: 0Last Post: 13-10-2005, 05:14 AM
