Results 1 to 12 of 12
Thread: Thermomax controller
08-05-2007, 08:57 PM #1
thermomax controller
I have a cold room with a thermomax crx100 the hi alarm light keeps flashing
I have adjusted the hi and low alarm set points but every 15 mins the alarm resets
evap coils reads -6 room set +3 coil clear
08-05-2007, 10:45 PM #2
Re: Thermomax controller
This is taken from the manual ....
Alarm reset:
To reset the alarm, adjust the temperature which has been exceeded beyond the current room temperature (AL-HI or AL-LO).
and go get a cuppa
08-05-2007, 11:11 PM #3
If you haven't got a manual for this controller then download one here...
http://www.thermomax-group.com/PRODU...als/rcxeng.pdfBrian - Newton Abbot, Devon, UK
18-01-2010, 07:31 PM #4
Hi Brian, Ive got a Thermomax RCX 100 cotrolling a cold room. After a maintenance when I switched the cold room on, the evap fan runs but the controller shows Al-HI and all the and all the light s on the right of the display are on and the display is on with all sigments so cant read nothing.I tryed to reset the alarm but controler just beep if try to do anything. It would be really helpfull you could give me any ideas.Thanks
18-01-2010, 07:45 PM #5
Problem: The AL-LO or AL-HI indicator is flashing.
Cause / Remedy: This is not a fault. The ROOM temperature is or has been
either higher than the AL- HI set point, or lower than the
AL-LO set point.
18-01-2010, 08:17 PM #6
As with ALL faults/problems....Patience is the key element....
18-01-2010, 10:19 PM #7
Adjust the high limit above the room temperature, don't forget to rest it when the room has cooled down.
Have you read the manual??Last edited by Brian_UK; 18-01-2010 at 10:21 PM.
18-01-2010, 10:39 PM #8
20-01-2010, 08:07 PM #9
The thermomax has an EPROM memory which means it stores previous information even when the power is off. You cannot erase this information, you just need to get it past the obstacle and back in the right mode. As Brian says, just temporarily reset the limit to a new value above the present box temperature, and re-set it when back in range.
22-01-2010, 07:21 PM #10
Don't you all think - as I do - that it would be so gratifying to get a response for your efforts... Even if they tell you your advice was rubbish, it's better than totally ignoring what you have done for them... I have to say though that this applies NOT to the pro's, but more particularly to those who have obviously joined the forum in the hope of saving a few £/$/€ or whatever your currency is. Any thoughts?
22-01-2010, 08:29 PM #11
Its nice to hear back what happened and if or how a problem was resolved, it may help someone else to sort a similar fault.
Also i like fixing things, its what makes work fun so even when its just a bit of advice or an offered opinion that was given here, its nice to know it was helpful.
22-02-2011, 12:17 PM #12
Anyone got the correct link to thermo
Max please
Micro-cool controller
By bernard in forum Supermarket RefrigerationReplies: 6Last Post: 25-08-2006, 07:10 AM -
Help with new electronic refrigerator controller !
By EngiGal in forum New TechnologiesReplies: 17Last Post: 08-04-2006, 07:39 PM -
Controller wiring
By Mickvee in forum Air ConditioningReplies: 2Last Post: 30-12-2005, 02:04 AM -
Fan Controller
By Abe in forum Trouble ShootingReplies: 4Last Post: 12-01-2002, 02:21 AM
