Thread: Suction line
08-05-2007, 06:17 AM #1
Suction line
hi..
Can any one plz suggest what would be best metal to use for suction line for domestic refrigerators..or if combination for 2 metals then which would be the best choice..
Thanks n Regards
08-05-2007, 04:33 PM #2
08-05-2007, 05:17 PM #3
Re: Suction line
Hi there,
Most of the evaporators for domestic refrigerators are made with aluminum tubes. The condensers are from copper. The ones I saw anyway.
For joining them the manufacturers use some kind of glue!!!?
The suction line is also copper.
CheersEven Einstein Asked Questions
08-05-2007, 05:51 PM #4
Re: Suction line
They use a two pack epoxy resin... on domestic refrigeration, to join aluminuim to copper/steel.
08-05-2007, 05:58 PM #5
10-05-2007, 12:25 AM #6
Re: Suction line
We use a grey metal bi-component glue made in Argentina (!) for repairs on Al evaps in domestics., however, I have not seen any remains of glue on the Cu-Al joins to the evap. A mystery.
Suction gas <-> liquid line heat exchange and performance gains
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 18-05-2010, 01:52 PM -
Suction line designing for ref. systems
By Maxim in forum FundamentalsReplies: 19Last Post: 16-12-2006, 05:43 PM -
Bearing trouble - rotary compressor
By rosetennis in forum Industrial CompressorsReplies: 6Last Post: 18-05-2006, 01:26 AM -
Measure suction line pressure drop with thermometer
By Steve Wright in forum FundamentalsReplies: 7Last Post: 17-09-2005, 11:05 PM -
Minimal required R134a speed in suction line
By DaBit in forum CPU OverclockersReplies: 32Last Post: 08-05-2002, 05:19 AM
