Results 1 to 9 of 9
    Jan 2006
    Croatia
    68
    2,263
    31
    Question Sabroe SMC 112 Mk4 water cooled
    Hi, all
    This compressor has about 32000 working hours. still running good on ammonia at -10C/+35C (14F/95F).
    From your experience when an overhaul must be done?
    Which set of spare parts to use now A or B if is not time for overhaul - service C?
    Thanks for help.
    Best regards, Josip
    Jan 2007
    37
    Re: Sabroe SMC 112 Mk4 water cooled
    I Don't Know About A Or B But I Would Yank One Head And Look At The Valves And Go From There. I Would Also Clean All The Water Jackets. I Have The Smc 106 And Iam Trying To Find An Oil Filter Other Than Oem. At $300.00+ Us There Has To Be Something Else Out There
    Aug 2001
    NE Lincolnshire, UK
    145
    23
    Quote Originally Posted by Josip View Post
    Hi, all
    Thanks for help.
    Best regards, Josip
    Now you are having to buy kits rather than the individual spares, it pretty much means go by the book unless you want piles of odd unused spares lying around.
    I found Sabroe's could run up to 10 000 or even 12 000 hours before needing valve replacement on a steady state application such as a cold store. However, on process applications with "warm" starts and varying loads, I used to start looking for problems at 8 000 hours on valves.
    I'd do the "A" service and take the opportunity to check some of the more highly loaded components. If they look OK, leave alone, otherwise order a "B" kit and tackle that work later.
    If there are any cylinders running off-loaded for much of the time, I'd target them for some extra attention as they get quite hot.
    I could confidently leave the crank assembly and the rest until maybe 40 000 hours. Never had worn out pistons, liners or rings until maybe 100 000 hours, and only then on the hotter or more highly loaded cylinders.
    The other option is to do a big service now, measure wear rates, etc and then predict if you can run longer before you open it up again.
    Steve
    Aug 2001
    NE Lincolnshire, UK
    145
    23
    Quote Originally Posted by SIGNSTU View Post
    In the UK, I could get the old-style pleated paper filters made, but I had to order a minimum of either 12 or 20 (can't remember exactly). For that number, the price was around 50% of the OEM, but you still then needed gaskets that were only supplied in the kit.
    I spent a fair bit of time digging around as quite often, OEM filters are supplied by a filter manufacturer who will have something on the shelf to match filtration \ flow specifications specified by Sabroe or whoever.
    Once Sabroe (spit York) moved to the steel mesh "nut and bolt catchers" as opposed to the "proper" filters, I used to clean out these and reuse them. If your oil was kept clean and no metal was circulating around the system, they rarely clogged up so badly to need dumping.
    Saying that will a $300 OEM filter save you $Ouch! repair bill? Do you feel lucky? Well do you? To quote a well known US film star
    Steve
    Jul 2007
    Serbia
    48
    43
    Hi, all
    Thanks for help.
    Best regards, Josip
    ...Bok Josipe...
    ...Do you have SMC100 compressors.....
    ...thanks...
    Oct 2007
    AUCKLAND
    42
    7
    i have put fram (deisel oil filters )in mk 1&2 smc they work fine or there is a company in australia called iseco they will sell ripped sabroe spares.
    Oct 2007
    AUCKLAND
    42
    7
    the overhaul hours for most sabroe comps is 40000 but if im not mistaken they have changed that to 35000 so 32000 is fine
    remember 5000hours oil filter
    Jan 2006
    Croatia
    68
    2,263
    31
    Bok Sinke
    Quote Originally Posted by Sinke View Post
    ...Bok Josipe...
    ...thanks...
    Sorry for late replay, have been for long time in Vietnam in that time (after that in India) and somehow miss this post. It is originally mine, but later on client decide to buy new compressors...*****.
    No I do not have..., I am working like industrial supervisor engineer...mostly with ammonia plants with all kinds of compressors..
    Wish to thanks to all for good suggestions. Maybe need them for some other job...
    Best regards, Josip
    Jul 2007
    Serbia
    48
    43
    Bok Sinke
    Best regards, Josip
    ...OK...
    ...thanks anyway...
    ...new boss arived so,everything changed...
    ...I have one question,is Frigostroj Zagreb is still exist...
  1. Stal Water Cooled Shell & Tube Condensers
    By Samarjit Sen in forum Commercial
    Last Post: 18-02-2009, 01:46 AM
  2. How to adjust head on a water cooled condenser
    By kengineering in forum Technical Speculations
    Last Post: 30-05-2007, 10:37 PM
  3. York Water cooled solid state starter?
    By Dave the Fridge in forum Trouble Shooting
    Last Post: 27-03-2007, 05:03 PM
  4. water cooled
    By tait71 in forum Trouble Shooting
    Last Post: 02-03-2007, 06:22 PM
  5. water cooled condensers
    By aaron crimmins in forum Fundamentals
    Last Post: 22-07-2002, 04:24 PM
