Results 1 to 18 of 18
Thread: BTU and KW
    Apr 2001
    2,099
    27
    BTU and KW
    Someone said he got a 12000 Btu ac.
    I only work in metric, am wondering how many Kw that is
    Thank you
    ireland
    1,450
    41
    Re: BTU and KW
    Abe
    12 000 Btu/hour [I.T.] = 3.516 852 84 kilowatt
    From http://www.onlineconversion.com/power.htm
    Very useful site!!
    Al
    Feb 2005
    Aberdeen
    48
    168
    Re: BTU and KW
    Approximately 3.5 KW.
    Jase
    Apr 2001
    2,099
    27
    Re: BTU and KW
    Thanking you both for your help
    Oct 2005
    IRAN
    878
    Re: BTU and KW
    Hi Abe,
    I am sure you know this but I say it anyway.
    BTU is energy but kW is Power (energy/time).
    BTU/hr can be converted to kW.
    1 kW = 3412.14 Btu/hr
    Even Einstein Asked Questions
    Apr 2001
    2,099
    27
    Re: BTU and KW
    Thank you Lana
    As ever youre very informative and helpful
    Oct 2005
    IRAN
    878
    Re: BTU and KW
    Thank you Abe,
    You are very welcome. Glad to help.
    Feb 2007
    north west
    36
    243
    Re: BTU and KW
    hey fellas thos websites are great thanks alot adam
    NC
    262
    Re: BTU and KW
    This may be off subject but what are you guys opinions on using the formula:
    (Volts x amps) x 3.413/TD x 1.08=CFM
    Where the 1.08 is a variable based on what your conditions on the psychrometric chart are.
    1CFMx60 Minutes=60CFM/Hrx .075 (lbs per cubic foot standard conditions)=4.5 x .024(specific heat of air)=1.08 *this is the variable obviously where your plot on the psychrometic chart would vary for your ft³ per lb of air.
    This formula is given by at least one manufacturer to find the CFM on a Air Handling Unit with resistive heat strips. I ask this in this thread because of the obvious conversion for Btu's to Kilowatts. If anyone can chime in I am curious. I see this as reliable as what is used in cars for mass air flow systems since it's basically the same idea but I would like some opinions from some of you. Thanks in advance.
    Aug 2001
    1,046
    Re: BTU and KW
    It's an old formula that's been around for years. As a quick check it is OK but can be inherently inaccurate.
    I first encountered it in Carrier manuals in the 60’s and they stressed that you need at least 3 duct diameters of clear, straight, unobstructed duct, before and aft of your thermometer and both sides of the machine. Then you need to average a series of readings, just as you would with a Pitot tube.
    It is easy to get accurate temperature and electrical readings these days, but its main practical drawback and barrier to accuracy is obtaining even air flows at your measuring point at your site. At least, that’s my experience.
    Any inaccuracy here will throw your figures wildly out.
    As you probably know, finding this configuration at site is almost impossible and if you have such a straight piece of duct why not do a conventional traverse with a manometer?
    Great for a QLS, but I wouldn’t stand up in court on that evidence.
    NC
    262
    Re: BTU and KW
    Thanks. I am looking for basics of trying to figure out if I had an airflow problem or not. I will eventually get the TSI velocicalc. So many tools so little money.
    http://www.geotechenv.com/newfiles/velocicalc.html
    Aug 2001
    1,046
    Re: BTU and KW
    Well, This test is as basic as it gets.
    To determine if you have an air flow problem before you buy expensive software, look at your installation and try this simple visual check list:
    • Tight duct angles with few straight lengths
    • Blocked filters,
    • Long lengths of ribbed, flexible ducts.
    • Long distances in the room between the supply and return grilles.
    • Dusty coils.
    • Ineffective fan.
    • Etc
    It's a graded check, so if you can check any of those you have an air flow problem - the more you can check, the more expensive your problem.
    Oct 2001
    Nottingham UK
    5,668
    Re: BTU and KW
    You could always install a Wilson Flow Grid.
    http://airflowinstruments.co.uk/prod...x?Cid=1&Pid=40
    11,025
    Re: BTU and KW
    Been there, done that, can't afford the tee shirt now
    Have you noticed that the price is missing from the shopping basket?
    Got to admit that Airflow have done and still do some good kit.
    NC
    262
    Re: BTU and KW
    Thanks for the info sorry to go off topic somewhat.
    Nov 2006
    Cheshire, UK
    56
    360
    Re: BTU and KW
    Quote Originally Posted by Abe View Post
    Thank you
    Your just joking Abe, right?
    A site moderator with 1700+ posts not knowing basics such as this?
    Nah!
    Not having it, sorry!
    Apr 2006
    41
    1,620
    Re: BTU and KW
    I live in a metric country yet some how only ended up learning BTUs! Any thing is possible.
    Starting to get the handle between them though.
    NC
    262
    Re: BTU and KW
    http://www.megaconverter.com/mega2/
    For any conversion problems I have found so far this can pretty much do anything I have seen.
