Results 1 to 26 of 26
    Jan 2007
    UAE
    49
    13
    Carrier chiller basic board problem
    Dear friends I am facing problem on carrier pro dialog plus chiller Model 30GH 025 7290EE this chiller basic board faulty and i replaced with new basic board and removed EPROM from old board. But now display showing "conF" I checked chiller manual they mention when "conF" shows on the user interface this means that the basic board must be configured, this can only be done by carrier service
    Mar 2005
    u.a.e
    68
    169
    Re: Carrier chiller basic board problem
    Hi noushad
    Yes,
    You have to contact UTS CARRIER, They will up load the new board,
    This is the problem with all new chillers processor broads when ever a replacement is required you have to upload it by them.
    malik55
    Jan 2007
    UAE
    49
    13
    Quote Originally Posted by malik55 View Post
    Hi noushad
    Yes,
    malik55
    Thanks mr malik
    Mar 2005
    u.a.e
    68
    169
    It's okay, Go ahead
    Happy to share information if I had, Or may be someone else will help you.
    malik55
    Jul 2006
    Copenhagen
    Have you entered the password? Then you can configure the board youself?
    Mar 2005
    u.a.e
    68
    169
    HI conDor,
    The pass word is also a problem,
    Pro Dialog chillers usually has 2 pass word , the second one is for the factory set up, and that is not mentioned in any cats,
    DO YOU KNOW THAT ONE?
    malik55
    Mar 2007
    turkey
    11
    I guess it is Carel board. As far as I understand the eprom has not programmed yet. It has to be programmed by Carrier. Paswords will not help us. Passwords will heplp you after uploading the program to change the parameters.
    Best regards
    Coskun
    Jan 2007
    UAE
    49
    13
    Quote Originally Posted by ConDor View Post
    Mr. Condor you cannot enter the password first
    I want to be done configuration of my basic board this display only showing ‘CONF’ you cannot enter anything. Password normally creating for any one change the parameters and un-authorized person touching the display
    Jan 2007
    UAE
    49
    13
    Quote Originally Posted by coztemur View Post
    Best regards
    Coskun
    Hi MR. Coskun
    Your right but this is basic board OP12AS001 and 2nos EPROM U2&U3 but we required to program basic board because EPROM we removed old this is working other board
    Mar 2005
    u.a.e
    68
    169
    Hi Costemur
    You are right, the board must first be uploaded and configured, the pass words required for system testing and system setup,
    This is for most of the new systems which has micro processor controllers, This is a money making business the manufacturers keeps secrets with them for to make good money, I still remember the old horses, you can at least run the machine by making some alterations, and now if a you don't have a same sensor,transducer, p.c board even a switch the whole system is dead and we feel shame about that we can not fix it.......
    malik55
    Jul 2006
    Copenhagen
    Of couse you can program the board (on site), it is a bit tricky, but possible. You will just need the old eprom, the password, and the advanced manual (a few of carriers industrial engineers have it, and know how to do it on site). But you can also use a laptop and a hasp, that is much fastere.
    Nov 2005
    Ireland
    When a new board is fitted, it will display Conf. The only way to programme the board is by Carrier Rep using "Carrier Service Tool" with a laptop. In behind the display is a sticker with a code starting with 88CS_ _ _. They will use that code to upload the correct information.
    Jul 2006
    Copenhagen
    It is right that you program the board from the number written inside of the electrical box. The number is identifying what purpose the controller is used for, what refrigerant is used and so on. But it is NOT right, that you can't program it on site without a laptop. Just read the advanced manual, there is a good explanation, on how to do it. But i dont know how hard it is to get, they probably wont give it to everyone. They also have to make a living
    LRAC's Avatar
    LRAC is offline Veteran Poster I am starting to push the Mods: of RE
    Sep 2006
    Midlands
    453
    Hi all
    http://www.uk.carrier.com/products/C...n%20ranges.htm
    Go to this site find your chiller and download the manual for your controller, it can be done without the laptop it just take great deal of consentration.
    we only call in Carrier as a last resort.
    Lrac
    TCUK's Avatar
    TCUK Guest
    You need to call carrier service an enginer will come out with the correct softwear and upload it.
    moideen's Avatar
    Apr 2008
    u.a.e
    49
    412
    Question Re: Carrier chiller basic board problem
    Quote Originally Posted by noushad123 View Post
    hi noushad,when you purchase anew board,it is allready programmed.especially in carrier chiller not remove "eprom".if u remove eprom program will be cancelled.may i know when you buy new processor board,is there not included 'eprom"?
    regards
    moideen
    4,713
    TCUK and Moideen.
    Did either of you note when these post were added?
    IE. 2007
    May 2008
    uae
    44
    40
    hi guys,
    i am also facing the same problem with carrier 30gx chiller in my cause compressor scpm board (alarm is loss of comunication with scpm board 3) we tried to replace new board but same alarm comes back does this board also requres software.
    Apr 2009
    israel
    778
    hi there as said before on this forum no u dont need to configure a compressor board only make sure your dip's are set as previous board and comm is connected ok
    good luck
    Nov 2005
    Ireland
    Quote Originally Posted by anish View Post
    hi guys,
    The compressor board does need software but this should have been done before you got it. The board has a few different uses and needs the correct software for a screw compressor. Ask your Carrier supplier if the software was programmed onto the board. If it has the software, carry out Goshen advice on checking your connections.
    ron21gallosa's Avatar
    ron21gallosa Guest
    hi guys...
    i have a pending alarm on my 30gh050 chiller (alarm code 503)...
    also i am looking for the manual for the same model...
    hope u guys can help me out...
    tnx... and more power...
    ron
    Apr 2009
    israel
    778
    hi there hi pressure circuit 5
    good luck
  23. #23
    Dec 2005
    Johor
    151
    Ron21 pm me. I'll get you the manual.
  24. #24
    May 2008
    66
    802
    how old is the plant??? maybe its time to clean the condenser.
    Ice
  25. #25
    vivek's Avatar
    vivek Guest
    Mr.Condor,
    can you please describe the steps how to Configure. Thanks
  26. #26
    vivek's Avatar
    vivek Guest
    Mr.Lrac,
    Can you please describe the steps to configure the board and eeproms.
    thanks
  1. Carrier Transicold problem
    By tsvetomir in forum Transport
    Last Post: 16-08-2010, 02:59 AM
  2. Trane HP Defrost Board Problem
    By FastEd in forum Heat Pumps
    Last Post: 05-09-2008, 01:30 AM
  3. York YK Chiller Problem
    By icebox in forum Refrigeration Books
    Last Post: 01-07-2008, 06:05 PM
  4. Carrier Chiller Help
    By superswill in forum Trouble Shooting
    Last Post: 18-01-2007, 10:06 PM
  5. Carrier chiller oil migration
    By lowtech in forum Industrial
    Last Post: 30-04-2006, 04:11 PM
