Thread: Carrier ZR 19 Centrifs
30-04-2007, 08:24 AM #1
Has anyone experienced bearing failures or bearing design faults on these chillers as I have a site who has lost chillers now,al with the impellers smashed to pieces costing loads of dosh.Any help would be appreciated.Cheers.
30-04-2007, 09:53 PM #2
Re: Carrier ZR 19 Centrifs
have heard and seen some failure of bearings, usually do to oil problems, like worn oilpumps and lack of oil due to surging and oil pressostat not working properly!
What age is the unit and how many hours has it run? And how many starts/stops?Last edited by Lowrider; 30-04-2007 at 09:54 PM. Reason: adding question
03-05-2007, 12:00 AM #3
I'll assume this is a 19XR model. Never seen a ZR in the USA. I take it you are discussing the Kingsbury Thrust failing. Surging on these chillers will chew up the thrust real quickly, they tend to be prone to surging if running outside thier design envelope even slightly. There doesn't seem to be a rash of failures of this type in my area. JMHO
Carrier 19XR Centrifs
By wkd in forum Trouble ShootingReplies: 13Last Post: 27-08-2010, 07:32 PM -
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Carrier Chiller Help
By superswill in forum Trouble ShootingReplies: 7Last Post: 18-01-2007, 10:06 PM -
Carrier chiller oil migration
By lowtech in forum IndustrialReplies: 5Last Post: 30-04-2006, 04:11 PM -
carrier remote
By superswill in forum Trouble ShootingReplies: 2Last Post: 26-04-2006, 09:17 PM
