Results 1 to 14 of 14
Thread: Refrigeration floorheating
29-04-2007, 10:26 AM #1
Hello all,
I have a question that maybe one of you can answer.
Sometimes we need to lay floorheating for a industrial freezer, now my question.
For a blast freezer we lay the floortubes at 20 cm from each other, but for a normal freezer we lay them 50 cm from each other. Even when they work on the same evap temp.
Same thing with the isolation, sometimes we lay it 7cm thick and othertimes 20 cm thick.
Has that something to do with the glycol solution/watertemp that flows trough the floorheating?
Or is there no standard for floorheating.
Thx in advanced,
Klaverlover
29-04-2007, 04:39 PM #2
Re: Refrigeration floorheating
It has to do with the amount of watts needed. In floor heating in houses or office's the distance is 15 cm and the heating delivers 125W per m2, from the top of my head!
30-04-2007, 08:18 PM #3
Klaverlover, welkom op ons wereldwijde forum. Finally a new Belgium member among us.
Long time we heard something from BESC5240.
Mag ik vragen, voor welk bedrijf werk je of van welk bedrijf ben je de zaakvoerder?
This is realy coincidence, I just wrote a technical article about this topic (+/- 3 or 4 pages) in the new C&C which will be published within some weeks.
For those interested - it's written in Dutch of course - I can post the article here or on an external server.
I there give some practical guidelines.
I also published some pictures of a froozen-up floor where the heating system failed, or better, was wrong engineered. (Veurne, langs de autostrade om meer precies te zijn)
These pictures were already posted somewhere on this forum.
There's no standard about this but there are some good guidelines and practical experience gained over the years.
In my opinion, the purpose of the application doesn't matter how far the tubes are spread in the underfloor.
The temperature in the freezer and the blast freezer is approximately the same. Anyhow, a difference from 20 cm to 50 cm is to much. Especially when a circuit should fail, you don't have any redundancy at all.
Isolation for an industrial freezer of 7 cm is not enough, at least 20 cm in 2 layers, seams not over each other.
Minimum = 7 to 10 W/m˛ (23 -> 34 BTU/h) and 20W/m˛ (68 BTU/h) to have some redundancy.Last edited by Peter_1; 30-04-2007 at 10:16 PM.
30-04-2007, 09:40 PM #4
30-04-2007, 10:14 PM #5
http://www.refrigeration-engineer.co...ead.php?t=3965
As soon the article is published, I will post it. Remember me within some weeks.
It looks better if I post it the way it's published. I just give my raw text together with the pictures.Last edited by Peter_1; 30-04-2007 at 10:26 PM.
30-04-2007, 10:56 PM #6
Here is some miscellaneous information I found.
http://www.bylinusa.com/cold_storage/frost.html
http://www.thermonfibreform.com/us/c...es/CPD1038.pdf
http://www.fao.org/docrep/003/V3630E/V3630E08.htm
Apparently, there is more public information available on electric heating for this purpose than warm glycol.If all else fails, ask for help.
30-04-2007, 09:09 PM #7
@ Peter_1: Do uou remember where the pictures are? Would like to see them and also read your article!
Thanx in advance!
09-06-2007, 03:42 PM #8
We are building a 60 m x 60 m x 12 m cold store complex with racking, Linde MHE, ( 5 Nos) , for -25 deg c in Mumbai India. panels & doors are from Germany , Raking from Spain.
We generally provide floor ventilation pipes being the most economical in terms of power. We have also used heaters, elevated floors etc. But 90% of our projects now use Ventilation pipes
09-06-2007, 04:53 PM #9
If you are speaking in terms of power, then underfloor heating via a HE in the discharge or liquid to the freezer is without any doubt the best way.
This can be proven thermodynamically.
You have to see this much wider and spread the eventual higher investment over a longer time and especially when you can increase seriously the COP.
And especially in your country with it's high temperaturesIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
10-06-2007, 06:38 AM #10
That is right. Infact as I can see, the floor heating/ pipes etc started in India may be in the last 15 years or so. I have seen no of old cold stores where in this point is not at all considered. Many a times to match the loading dock heights for container docking , the cold store needs to be built over elevated floors. I remember this point was discussed over a no of times when we were building the coldstore for Lever Ice cream factory. The Lever specs did call for Heaters, but eventually due to site conditions, elevated floors were used
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
