Results 1 to 15 of 15
    Feb 2006
    64
    Fresh air requirement question
    Hello I have a customer who has asked for a high wall mount inverter h/p & for a separate fresh air supply! it is for an office within a factory environment, office size = 40 cubic mts, max bodies = 10.... they don't want anything too sophisticated.. was thinking of a 4" duct fan with fresh air intake grille run from it's own separate electrical supply switch ( they can then operate it at will) The room is approx 4 to 6mts from exterior. I realise the a/c will have to be sized accordingly to cope with added fresh air gain ! would 8 litres per second per person be near ? at present our design source is unavailable.. can anyone give me some ideas/calcs etc.......thanks
    Nov 2006
    Australia
    59
    14
    Re: Fresh air requirement question
    Hi stevo
    Check out ASHRAE or similar governing bodies for the required air change for an occupied office airconditioning application. General cooling load W/m2 (air conditioned area) for a general office can be as high as 180 W/m2. Take into account the heat load from lighting, computers, fax machines etc. 8 litres per second per person is a bit extreme for fresh air make up...... are they on fire??? I would'nt have a manual switch for the office staff to operate at will. Put it on a timer to suit occupancy hours with manual overide or cycle it with operation of the aircon system, whatever you do, just cover yourself by not doing it on the cheap just to satisfy the client, if it doesnt work your phone will be ringing....
    Dec 2004
    Australia
    52
    519
    Mar 2006
    belfast
    239
    is there not a place on the indoor unit that u can fit a fresh air duct onto?
    Feb 2006
    64
    Quote Originally Posted by thebigcheese View Post
    No not on the high wall mount systems !....cheers
    Mar 2007
    South Africa
    228
    Quote Originally Posted by stevo View Post
    8 l/s/p is a bit high.
    If there is no smoking, you can go down to 2.5 l/s/p for a typical office. Fresh air is a big load so you should keep it to a minimum.
    You are right to base the quantity on the number of people. I have seen estimates based on a fraction of the supply air but this is when you don't have any better figures.
    Feb 2006
    64
    Thanks for your replies ! anyone else with ideas ?
    Oct 2001
    Nottingham UK
    5,668
    CIBSE guide recommends 8 l/s/person as a minimum fresh air requirement (20 l/s/person for airconditioned spaces) or 6 air changes per hour for an office environment.
    So, for 10 persons you would require 80 l/s or 0.08m3/s or for 6ACH you would require 0.67m3/s.
    The additional cooling load, UK conditions would be 1.51kw or 1.26kw respectively
    0.08m3/s would require a duct @ 150mm dia to give a reasonable velocity and pressure drop.
    Feb 2006
    64
    Many thanks Frank, Just the info i can use !
    Mar 2007
    South Africa
    228
    Good advice, always check your local requirements.
    In SA with +35degC ambient and poorly sealed buildings, we try to keep the fresh air to a minimum.
    ASHRAE does not actually give a fresh air recommendation but rather a guideline.
    Oct 2001
    Nottingham UK
    5,668
    Quote Originally Posted by nh3simman View Post
    The English CIBSE Guide is also a "Guide" but it is adopted by most design engineers to be incorporated into new build projects, as it sets a baseline for the performance of the services.
    Sep 2005
    South West
    129
    Both Hitachi & Daikin make fresh air wall mounted splits although i believe Hitachi are dis continuing theirs.
    Jun 2006
    British West Indies
    543
    2.5 l/s is bare bones minimum in many places. Think the first number ever used was 4 CFM per in the Houses of Parliament. Heard an urban legend they used to give coal miners 5 cfm per to keep productivity up.
    Mar 2007
    South Africa
    228
    Quote Originally Posted by Abby Normal View Post
    I wouldn't say 2.5l/s/p is a bare bones minumum.
    We add outside air for 2 reasons
    1. Supply of O2
    2. removal of CO2
    People need 0.2l/s of O2. This is a fresh air rate of 1 l/s/p.
    Feb 2006
    64
    Pheww thank god for that ay !!!
