    Jun 2005
    Quito
    65
    22
    Ammonia evaporative condenser surface
    Dear Friends:
    Does some body knows the surface area required per MBH at manufacturer std. conditions for a evaporative condenser.
    Best regards
    Gonzalo ARIAS
    Dec 2004
    Weihai,China
    807
    Re: Ammonia evaporative condenser surface
    It depends on the manufacturing. It is usually from 2kw/m2 ~4kw/m2 . Only for your ref. You can refer to the specific catalogue for it.
    regards
    LC
    Jun 2005
    Quito
    65
    22
    Thanks LC
    I think that Vilter, Baltimore, Evapco have about the same surface area, Do you Know this figures? also Kw/m2 that you stated are evaporator KW or total heat rejection KW?
    Best Regards
    Gonzalo
    Dec 2004
    Weihai,China
    807
    The ammonia evaporative condenser total heat rejection:2~3.3KW/M2 usually;we made copper tube evap condenser and the heat reject is at the upper level.
    Hope it can do some help for you. You'll design it or manufacture it?
    regards
    LC
    Jun 2005
    Quito
    65
    22
    TK, this will help, we use carbon steel pipe.
    Best Regards
    Gonzalo
