Results 1 to 11 of 11
    Dec 2006
    22
    Absolute Zero - how low can you go?
    Can anyone help me with this - as I understand it at
    -273K all motion stops at the molecular level and therefore no heat / energy can be present. However, I have recently been told that both Nitrogen and Helium can be taken below -273K.
    a. Why is absolute zero given as -273K?
    b. What is the lowest temperature for N2 / Helium?
    Apr 2006
    41
    1,620
    Re: Absolute Zero - how low can you go?
    We've never reached absolute dam close but never been.
    Helium is a couple Kalvin above absolute, LN2 is much warmer then Helium.
    And at absolute Zero we Canadians might say it's cold out
    Mar 2006
    Norfolk
    160
    Your understanding of the kelvin scale is slightly out.
    Zero degrees Kelvin is Absolute Zero and is -273.16 C
    Kelvin is a temperature scale designed so that zero degrees K is defined as absolute zero (at absolute zero, a hypothetical temperature, all molecular movement stops - all actual temperatures are above absolute zero) and the size of one unit is the same as the size of one degree Celsius. Water freezes at 273.16K; water boils at 373.16K.
    HTH
    Paula
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, alexdouglas1969
    Quote Originally Posted by alexdouglas1969
    b. What is the lowest temperature for N2/Helium?
    Wrong
    Please read this:
    http://en.wikipedia.org/wiki/Absolute_zero
    http://www.colorado.edu/physics/2000...mperature.html
    Best regards, Josip
    Mar 2007
    South Africa
    228
    I think that this is a very interesting subject.
    From the laws of thermodynamics, the lowest possible temperature is Zero Kelvin (or -273.15 degC).
    Actually reaching this limit seems to be like reaching the speed of light. Having said that, there have been some remarkable attempts at reaching this limit.
    Mark Zamansky has written a very good book "Temperatures, very low and very high", where he gives some of the history. The lowest temperature was
    1960, Kurti, England, Nuclear cooling methods, 10^-6 (1 millionth of a degree)
    I was told by Prof Rallis that in theory, it is possible to "bounce" below Zero Kelvin. How this works, I would not even speculate.
    Mar 2007
    South Africa
    228
    Hey Josip, thanks for this link. It looks worth reading.
    Apr 2007
    Toronto
    41
    7
    Absolute zero is the lowest possible temperature, occurring when no heat energy remains in a substance. Absolute zero is the point at which particles have a minimum energy
    from that statement alone reaching that point will be impossible
    Mar 2007
    South Africa
    228
    Quote Originally Posted by Athanatos View Post
    Then you would be interested to read "Beyond infinity to negative temperatures" by Zemansky.
    The definition of absolute temperture is purely a "large scale" concept. No reference is made of molecules or to molecular energy. The statement that all molecular activity ceases at zero Kelvin is wrong. Modern atomic theory has shown that atoms of a solid at abs zero have a store of kinetic energy called "zero point energy", which may be considerable.
    Quote: Mark Zemansky
    Aug 2005
    5,302
    Here is an interesting link for those inclined to read theoretical physics.
    http://freeenergynews.com/Directory/ZPE/index.html
    Mar 2007
    South Africa
    228
    One of the things that I like the most about the Refrigeration Engineer web site is the free association of ideas. You start out thinking you know about something and are often treated to ideas that you never even considered.
    I invariably end up reading something completely different and this freeenergynews site looks like one of those sidetracks.
    Aug 2005
    5,302
    Quote Originally Posted by nh3simman
    That's what I like about this business. It is NEVER boring.
    If you want some other fascinating information look for Einsteins' refrigerator and the notion of a bubble pump. The other topic is related to Tesla and his idea of how a refrigeration system should work.
    Not quite on par with zero point energy, but close!
