Results 1 to 14 of 14
11-04-2007, 09:29 AM #1
Hooking up a Vaillant Geyser? Need help!
I have searched the net and all I get are adds and listings for units for sale, but what I need are hook up instructions, Does any one have the instructions in PDF format or a page of instructions they could scan of where the water in out ports are and such?
Thanks to any whom can help, I been searching for so long with no result!
Unit is: MAG 125/7 TZ PB
11-04-2007, 01:52 PM #2
Re: Hooking up a Vaillant Geyser? Need help!
Try here:-
http://www.vailliant.co.uk/Last edited by Paulajayne; 11-04-2007 at 01:55 PM.
11-04-2007, 07:18 PM #3
Thanks but it apears it is just more advertising, infact If I recall I was there just befor I posted the above.
11-04-2007, 07:50 PM #4
That's because it is the wrong site, try this one...
http://www.vaillant.co.uk/Home/Products/Brian - Newton Abbot, Devon, UK
11-04-2007, 08:40 PM #5
Do you se your type amongst these http://www.vaillant.be/stepone2/data...gas_NL2006.pdf
11-04-2007, 09:22 PM #6
Normally hot water on the left, gas in the middle, cold water on the right and exhaust on top!
At least 0,5m of straight exhaust pipe before any bend!
11-04-2007, 10:15 PM #7
Gas and exuast are easy How ever how they have the water is rather confusing!
Here are some pictures of my unit, So far gas is very simple, one inlet, water how ever there are 3 options, It looks like a flow through design, so water can return to a storage tank un heated, so a pump may opperate with out high back pressur, or so it appears?
All most seems as there are two water inlets then the one outlet.Last edited by The MG Pony; 09-11-2007 at 07:01 PM.
11-04-2007, 10:30 PM #8
The one with the small valve is cold water inlet. The one below, the hot water outlet. The one on the bottom (the hosepillar one!) is also an outlet, for instance if the geyser is placed over a sink. This one is operated by the two spindels sticking out in the front. The mid one is the suppletion valve, this will add cold water to the hot water is the temperature desired is too high and will increase flow.
If the geyser is in the hallway, for instance, and you have multiple taps use the one below the cold water!Last edited by Lowrider; 11-04-2007 at 10:31 PM. Reason: additional info
11-04-2007, 10:36 PM #9
Oh could you do me a huge favour and lable on the pictur? I'd love you for it! been trying to figure this thing out over several months now!
11-04-2007, 10:58 PM #10
Here you go!
Should have the manual somewere in a box, will have a look soon!
Good luck!Last edited by Lowrider; 22-09-2007 at 10:01 PM.
11-04-2007, 11:18 PM #11
Tekst in these pictures are better!
11-04-2007, 11:51 PM #12
OMFG THANK YOU!!!! That makes perfect sense Now!
12-04-2007, 12:11 PM #13
Here you can find the manual, unfortunately in Dutch and French.
If you need help with the translation, let me know.
http://www.megaupload.com/nl/?d=IF5QB2ICIt's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
12-04-2007, 06:52 PM #14
Thanks, this will probly prove very use full as well, you would not believe how long I been trying to get info on this thing!
