Results 1 to 8 of 8
Thread: r421a
    Dec 2004
    Weihai,China
    800
    r421a
    How about the r421a? It's almost same as r22.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: r421a
    There are other replacements for R22, like R421B, R422D, R426A, R424A. Unfortunately, the availability is almost nil, as well as the suitable components.
    Nov 2006
    Australia
    59
    14
    Re: r421a
    Hi Lc_shi
    I have been using R417A as a replacement for R22 refrigerant in air conditioning systems. There is no need to replace the mineral oil in the system with synthetic oil as R417A is compatible with the existing mineral oil in the R22 system. The R417A has however a glide of about 8 deg kelvin. It has a high critical temperature which is also suitable for heatpump applications. I buy the refrigerant through heatcraft in Australia. It is an "A-Gas" product.
    Apr 2008
    Huddersfield
    Re: r421a
    im working towards replacing R22 with an sutible refrigerant but the project im working on is huge, including 10's of medium and low temp cases. Ive spent countless hours researching R417A and R421A and these seem like a possible solution. Can anyone Help me out with any other surgestions? cheers
    Jan 2008
    Kent UK
    49
    514
    Re: r421a
    Hi Have you had a look at RS45(r434a)it is a replacement for r22 in low and med temp applications and a/c
    Heres the data sheets
    http://www.refsols.com/RS-45.html
    Have fun
    If it ain't broke, it doesn't have enough features yet.
    Damo
    Apr 2008
    Huddersfield
    Thumbs up Re: r421a
    thanks alot, thats defernetly saved me time, and the COP's better than most choices ive researched
    rmsgas's Avatar
    rmsgas Guest
    Re: r421a
    Brad we have some experience in R421A in medium and low temp rack systems. I also have used a lot of R417a in the past. email contact info and I 'll help
    Quote Originally Posted by brad__34 View Post
    rmsgas's Avatar
    rmsgas Guest
    Re: r421a
    R421a in rack systems is working fine for medium and low temp
