Results 1 to 11 of 11
05-04-2007, 08:51 AM #1
Refrigerant Compressor is Sweating
A certain refrigerant compressed air dryer during operation the refrigerant compressor is sweating**(is always wet) and cause often a short circuit and**the
protection device (RCD) energised .**Usualy this is caused if a liquid refregerant is returning to the compressor.
Can you comment please?
05-04-2007, 09:03 AM #2
Re: Refrigerant Compressor is Sweating
Hi there,
You have to describe your system more than that. What is the actual application of your system?
What kind of evaporator is there?
Is there a TEV or cap tube?
and many more questions......
Give us more info.
CheersEven Einstein Asked Questions
05-04-2007, 11:33 AM #3
It humid ambients, it is perfectly normal that the suction side of the compressor is sweating. It is not normal that the condensate drips over an electric component and trips it. Just protect the device by making sure any more drop drips over the electric parts.
05-04-2007, 07:20 PM #4
You need to check that the air flow through the drier is as normal.
Some air drier have a hot gas bypass, or similar, to control the load of the evaporator. You need to monitor the temperatures through the system so that the system operation can be analysed properly.Brian - Newton Abbot, Devon, UK
07-04-2007, 03:06 PM #5
Could it be that your getting liquid back to the compressor. check your bulb if you have an x-valve and make sure is is all the way down in the well
15-04-2007, 10:59 PM #6
HA i work for ingersoll rand as a dryer tech if you tell me the make and model I can probable help you out
15-04-2007, 11:11 PM #7
Hi B4R and welcome to the forum.
16-04-2007, 10:21 AM #8
16-04-2007, 10:48 AM #9
Dear all,
Can you please help me?
I have to know about the specific heat of MILK KHOA to work out a cold storage calculation.
Kindly reply to my personal ID :tjk2007@gmail.com
Thank you Very much.
16-04-2007, 11:03 AM #10
It is off topic in this thread. I don't know what KHOA is, but I assume is milk, like any other cow milk
Composition of milk:
87.3 % water
3.9 % milk fat
8.8 % solids-not fat
3.25 % protein ( ¾ casein)
4.6 % lactose
0.65 % minerals (Ca, P, citrate, Mg, K, Na, Zn, Cl, Fe, Cu, sulfate, bicarbonate)
0.18 % acids (citrate, formate, acetate, lactate, oxalate)
enzymes, gases, vitamins
Milk Fractions:
Plasma (skim milk or milk minus fat)
Serum (plasma minus whey [casein micelles])
SNF (solids-not fat [proteins, lactose, minerals, acids, enzymes, vitamins])
Total Milk Solids (fat plus SNF)
Physical Properties of milkfat: density at 20° C is 915 kg/m3 refractive index (589 nm) is 1.462 which decreases with increasing temperature solubility of water in fat is 0.14 % at 20° C and increases with increasing temperatures thermal conductivity is about 0.17 J/ msK at 20° C specific heat at 40° C is about 2.1 kJ/ kg K electrical conductivity is < 10/ohm cm dielectric constant is about 3.1
16-04-2007, 11:05 AM #11
87.3 % water
3.9 % milk fat
4.6 % lactose
Milk Fractions:
