Thread: centrifs
04-04-2007, 10:45 PM #1
centrifs
Hello every one, got a leak on york centrifugal compressor between the joint where the motor joins the compressor, is it posiable the low pressure seal is gone and the oil is comming out the joint, and if so can it be changed in position with out having to seperate the motor completely.
05-04-2007, 12:03 AM #2
Re: centrifs
what model/gas is this unit?
Al
05-04-2007, 10:12 PM #3
Re: centrifs
Hello AL thankyou for your reply the mqdel is YDTJ 85 the gas is R123 LOW PRESSURE
07-04-2007, 02:07 AM #4
Re: centrifs
You will need to remove the motor coupling and slide the motor back to replace the shaft seal. Make sure to remove alignment dowels if there are any on the motor base.
07-04-2007, 06:02 AM #5
