Results 1 to 17 of 17
    Nov 2005
    211
    environmentally safe and more efficient?
    http://www.es-refrigerants.com/produ...ts/default.asp
    Has anyone used these refrigerants before? They claim to be environmentally friendly and more efficient. However, it sounds too good to be true and no OEM is using it.
    They appear to be mixtures since they are to be liquid charged.
    "If Hannah was an air handler, I would be a condensing unit so I could open her TXV and pump my refrigerant through her coils." - a HVAC friend of mine
    11,025
    Re: environmentally safe and more efficient?
    Being a hydrocarbon I would think that the 'home' user market is a bit limited.
    Nov 2006
    63
    392
    Looks a bit like either Isobutane or Propane looking at the data sheets.
    Ian
    11,025
    They'll be using lighter fluid soon
    Nov 2006
    63
    392
    Brian
    as long as they do not start using whisky they can do what they want.
    Ian
    Apr 2006
    1,620
    It is a Iso-Butane / Propane mix, another type I've seen was a mix of R-134a and Propane. I have a nifty PDF on it
    If interested I can email it to thoughs interested, unfortunately too big to put here
    Nov 2005
    211
    Is it actually more efficient?
    Apr 2006
    1,620
    Being propane has a lower head pressure it uses less power for a given amount. I'll have to do a comparison in a A/C.
    Oct 2005
    IRAN
    878
    Hi everybody,
    If these refrigerants contain Propane and ... aren't they flammable?
    Even Einstein Asked Questions
    Apr 2006
    1,620
    So what? All refrigerants are flammable when in a system due to oil any way? Are we so ragingly incompetent that we really need to worry? Only way it'll go up is if the building is on fire and frankly at that point it really is a moot issue any way, no?
    Croatia
    68
    2,261
    Hi, The MG Pony
    Quote Originally Posted by The MG Pony View Post
    When they are in system we do not have any problem .
    If the building is on fire it is time to run away , but
    with flammable refrigerants we have problem if there is a leak on system and with simple click on light switch/door bell we can have explosion.
    Anyhow I support use of HC as refrigerants of course with proper equipment and all safety measures. Maybe with some restriction for home DIY maestros
    Let's hear other members here.
    Best regards, Josip
    11,025
    I think the most that HCs are used in the UK is for domestic refrigerators.
    Apr 2006
    1,620
    And Europe.
    Josip, you are indeed correct hence why I ask, Are we so bad at building/ designing this most be a worry? and that even in such cases air flow and such ensures no flammability, you simply loose the charge, any thing short of a catastrophic failure of a joint or pipe will not form a combustible mixture of such a degree one would need to worry in a real world setting.
    Oct 2005
    IRAN
    878
    Dear The MG Pony,
    I have contacted their representative and the first thing they asked me was :
    What is the charge for your system and what is the application?
    I asked : what do need this for?
    Reply : We have to look at the chart and tell you if it is safe for your system. For some applications there is a charge limit which you can use according to the safety standards.
    Best regards
    LANA
    Apr 2006
    1,620
    Yes I know and am aware of this, they limmit the charge to 150Kg or 150G pending the aplication. Yet again though it is over protection, if the system is well built and has a means of safely burning off the charge there is no reason for it, with well don electrical it all should be air tight and water tight any way being from a very wet climate it is only good sense. Again any thing is only as safe as the person using it.
    Aug 2005
    5,302
    Unfortunately, it is not up to you to decide what is safe or sufficient. That's why we have safety codes. HC refrigeration systems are not much different than any other refrigeration system, except for the electrical (explosion-proof) requirements and oil return systems.
    In some instances the air tight/water tight argument doesn't hold water if you will pardon the pun. It is up to the facilities insurance company to determine whether they can use the equivalent of NEMA-4 purged panels or if they have to use explosion proof panels. A very big difference.
    From the presentation of your arguments it appears you are trying to justify doing something different than what the safety codes require.
    Or the person who designed the system.
    Apr 2006
    1,620
    Exactly No by my arguments I am saying all work should exceed the codes requirements no matter the system, if one can do a job that exceeds the code with out making the price insurmountable then it should be don. I try to build every thing to handle heavy abuse and to be solid, far to many things now days are designed to be throw-en away, where I like to make things that can be repaired for the next 50++ years and be safe even in a fire (well as best one can any ways).
