    Jun 2002
    Portugal
    42
    Can anyone help me w this compressor!?
    Hey guys,
    Ive got a compressor from a fridge and I need to know what spec it have.
    In the label says R12 152w, does this means that this compressor is a 152w at -20c?
    And, since R12 is now ilegal, can I use r134 for the compressor?
    Apr 2001
    Tyler, Texas
    12
    THe 152W may be the manufactures code., OR how many watts it can consume. But SInce r-12 is no longer produced. You are doing to have to find a good drop in. R-134a will not work unless you have the new oils in it.
    Preston Roy Powell
    www.thinkcool.net
    Jul 2002
    washington
    77
    22
    Depending on what your going to use that compressor for changes the refridgerant that you should use.
    If you need this for something low temperature, i am going to recommend propane (not stuff from the BB-Q, but pure propane)
    one mans trash is another mans treasure
    Sep 2001
    London
    The compressor was manufactured by Unidad in Spain. The 152w
    is probably the compressor power Is there a number like AE1336A or L45AU on it? This would be the model number of the compressor.
    Len Fiddler
  1. can overfilling/overcharging damage a compressor?
    By fredjchavez in forum Trouble Shooting
    Last Post: 12-02-2009, 10:30 AM
  2. Compressor pumping efficiency
    By shogun7 in forum Fundamentals
    Last Post: 25-02-2004, 10:50 PM
  3. One Half of a Part Wound Compressor Motor is Burnt
    By aygul in forum Trouble Shooting
    Last Post: 25-08-2003, 11:11 AM
  4. Compressor failure...... cause
    By herefishy in forum Technical Speculations
    Last Post: 06-12-2002, 12:15 AM
  5. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
