11-06-2002, 06:51 PM #1
Condensing temperatures with ammonia
Can anybody tell me which is the most common condensing temperature for ammonia? In my company we´ve been seeing that one problem with R-404A is the condensing temperature (50-52ºC) while R-22 could condensate at 62ºC; OK I understand this looking at P-h diagrams, but someone has told me that ammonia doesn´t condensate too high why??? the T critical of ammonia is 132ºC. ( I hope somebody understand my english :
11-06-2002, 08:08 PM #2
Hi, Friobernal most NH3 systems are designed around a 35c condensing temperature using evaporative condensers. Why condenser at 50c when you don't have to. Besides high condensing pressures in NH3 lead to very high discharge temperature, which can breakdown miniral oils and overheat compressors.
Regards. Andy.If you can't fix it leave it that no one else will:rolleyes:
12-07-2002, 02:50 PM #3
Condens pressure+NH3
On recaiprocating compressors too high condensing temperature if often a problem. A temperature about 125-150°C is commen. This temperature and higher damage the valve plates much fastar then for instant R22.
contaminants in ammonia systems
By Johnny Rod in forum RefrigerantsReplies: 29Last Post: 17-10-2011, 05:26 PM -
CARE refigerants by BOC
By dogma in forum RefrigerantsReplies: 8Last Post: 23-03-2010, 12:39 PM -
Want to be trained as an ammonia operator
By Randy Williams in forum NH3Replies: 7Last Post: 26-11-2008, 08:15 PM -
New Ammonia Certification in United States
By JerrydNH3 in forum NH3Replies: 11Last Post: 15-08-2006, 03:10 PM -
Condensing temp in refrigeration
By anup in forum FundamentalsReplies: 1Last Post: 02-10-2005, 11:18 AM
