Results 1 to 10 of 10
Thread: p-h charts
    vikki's Avatar
    vikki Guest
    Question p-h charts
    Where can I find pressure enthalpy charts for R404a R22 and for other refrigerants(HFC?HCFC)?
    St. Louis, MO
    510
    ASHRAE Fundamentals Handbook is a good place to start. The major refrigerant manufacturers will also provide you with these charts.
    Prof Sporlan
    Jan 2002
    Austin, Texas
    718
    23
    http://www.scacdtechsupport.com/pres...ture_chart.htm
    ... has some refrigerants listed. You can do a web search and find others if you're interested in on-line info.
    vikki's Avatar
    vikki Guest
    thanks but i already tried them they do give us pressure temperature charts but no pressure enthalpy charts .....ASHRAE is one place i havent checked will try that
    Probus's Avatar
    Probus Guest
    Nikki, Try this site.
    http://www.solvay-fluor.com/produkte...me_kaelte.html
    If you follow the links, it contains info on all the refrigerants you mention. The ph chart is also referred to as a Mollier diagram. You will need adobe reader to see it.
    The resolution is not good on the screen and it's a lengthy down load.
    Your best bet is to ask one of the manufacturers for a CD ROM, or a paper version, which is usually A3 size. SOLVAY are very good for this, their technical info is excellent. They used to give them away free.
    Good Luck
    Probus
    Oct 2001
    Nottingham UK
    5,733
    if you download this very good program you can print out your own ph charts http://fridgetech.com/software/coolpack.exe
    Mar 2002
    Spain
    67
    23
    You can find what you are looking for downloading a program in this site:
    http://www.et.dtu.dk/CoolPack/uk/Index.html
    vikki's Avatar
    vikki Guest
    Thanks' a lot guys ......the coolpack s/w had all the answers i needded
    AmilaHNDESL's Avatar
    AmilaHNDESL Guest
    Re: p-h charts
    I want Details about ph chart. Can U ?
    11,192
    Re: p-h charts
    Quote Originally Posted by AmilaHNDESL View Post
    Welcome to the forum.
    If you want software that will provide you with PH charts then please read the posts above, they contain links to CoolPack.
  1. glycol charts
    By Feargal Loy in forum Technical Speculations
    Last Post: 28-03-2010, 03:19 AM
  2. Replies: 6
    Last Post: 10-09-2008, 12:12 PM
  3. P-T Chart(s)
    By HVACGod in forum Refrigerants
    Last Post: 24-05-2006, 12:17 AM
  4. superheat/subcool charts.
    By Temprite in forum Air Conditioning
    Last Post: 14-08-2005, 06:56 AM
  5. p/t charts
    By milton in forum Refrigerants
    Last Post: 14-06-2004, 07:20 PM
