Thread: Heat Transfer Exam Question
24-03-2007, 03:22 PM #1
Exam question:
Heat transfer takes place whenever there is a:
a Pressure difference
b Temperature difference
c Specific heat difference
d Latent heat difference
Any thoughts on this question would be very welcome, thanks.
24-03-2007, 07:25 PM #2
Re: Heat Transfer Exam Question
The answer has to be 'B' surely.
It doesn't matter what the type of heat is it's the fact that there is a difference that makes the transfer occur.Brian - Newton Abbot, Devon, UK
24-03-2007, 11:13 PM #3
Well our tutor would agree with you but thinking of the psychrometric chart - I would say 'C' is more correct - after all, temperature is not heat...
Anyone else got an opinion?
24-03-2007, 11:18 PM #4
OK, I'll pose this question...
How do you quantify the difference between two items of different latent heat?
(Latent Heat is defined as the heat which flows to or from a material without a change to temperature. The heat will only change the structure or phase of the material. e.g. melting or boiling of pure materials)
(The amount of heat transferred delta Q is proportional to the temperature difference delta T between the objects and the heat capacity c of the object.)Last edited by Brian_UK; 24-03-2007 at 11:23 PM.
24-03-2007, 11:50 PM #5
The answer is "B" as you need a Delta T for either specific heat or latent heat to be absorbed or given up.
So I agree with Brian on this one, without this principle which is the second Law of Thermodynamics we all would be out of a job.
Ian
25-03-2007, 02:21 PM #6
Have given this some more thought now - obviously not C as specific heat is amount of energy per unit mass to raise by one degree (or temperature unit) so C just does not make sense - I agree B is correct. Thanks for the help, I was stuck on the definition of temperature - for example the same level of heat can be given by different temperature scales, therefore a difference in temperature does not necessarily cause flow of energy... what a muddle... thanks... !!!11
25-03-2007, 04:46 PM #7
The temperature scale (Fahrenheit, Celcius, Rankine, Kelvin) is a MEASURE of temperature (heat energy) from a base point, whereas Specific heat or Latent heat are a measure of heat carrying capacity.
Pressure has nothing to do with temperature in this instance.
26-03-2007, 12:01 AM #8
Frank
specific heat is a measure of heat carrying capacity whereas latent heat is the amount of heat required to change phase so not really heat carrying potential, or am I being a tad pedantic.
Ian
26-03-2007, 09:11 PM #9
Hi Ian
Nit Picking, hmm, maybe. Seems we've covered it now though
You know what I was trying to say
13-12-2008, 11:51 AM #10
Heat tranfer depends only where, there is difference in temprature.......
13-12-2008, 04:19 PM #11
There is no transfer if there is no temperature difference.
The answer is B.
