Results 1 to 8 of 8
Thread: daikin ac charge problem
24-03-2007, 09:00 AM #1
Hi, I'm working on a daikin ducted system with an outdoor unit R125FJ7W1 refrigerant is R22 and the pipe length of about 10mtrs, can anyone help with the correct charge, starting and running current for this unit?
24-03-2007, 08:02 PM #2
Re: daikin ac charge problem
The data you want should be on the plate attached to the unit.
24-03-2007, 08:43 PM #3
Thread.
It's my first reply on this forum i hope you'll find answer with the following attachement (pdf).
cool#9Last edited by cool#9; 09-10-2007 at 05:16 PM.
25-03-2007, 09:37 AM #4
25-03-2007, 09:39 AM #5
25-03-2007, 11:23 AM #6
Colicool
I checked the data of R125FY1 and the original charge is 3.0 kgs of R22.
The main difference between R125FJ7W1 and R125FY1 is that the first one is from Daikin Europe Factory so the technical data must be good.
cool#9
25-03-2007, 03:20 PM #7
31-03-2007, 06:16 AM #8
they are usaully pre charged for a 30 metre pipe run and if a remember its 54grams per metre extra
