    gagrandy's Avatar
    gagrandy Guest
    Dehumidifier Ideas?
    HI, I am looking to create a dehumidfier for my deer blind. Our window fogs up really bad. It is air tight and heated to about 75 degrees. It is needed during seasson when it is about 30 degrees or below out side. I cant have a compressor run becuase it is too loud. Plus if i am going to use snow to cool the liquid in the system then the coils outside have to be at ground level, where as the coils inside the blind are 12 feet up. I was thinking of some sort of siphon system maybe. Any ideas would be greatfully apreciated.
    Mar 2006
    Merate (LC) - Italy
    2,549
    Re: Dehumidifier Ideas?
    Just install a crossflow heat exchanger with exhaust heat recovery.
    Baltur, Termocold, FCR and many more produce these sort of things. Very cost effective and energy efficient. No need to mess up with the snow.
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by gagrandy View Post
    The problem is that your blind is too air tight. You need to bring in outdoor air, heat it, blow it at the window. That outdoor air, when heated, will be very very dry.
    30F air @ 100% relative humidity, will warm up to about 20% relative humidity @ 75F.
    30F air @ 50% relative humidity will be about 10% relative humidity when heated to 75F.
    The colder the outdoor air, the dryer it will be when warmed to 75F.
    Jun 2006
    British West Indies
    543
    just ventilate
    pennswoodsed's Avatar
    pennswoodsed Guest
    Would a small inlet tube from outside to cold side of heater add the needed percentage of fresh air?
