    Mar 2007
    INDIA
    42
    31
    Tanem unit and Booster unit
    Can you explain the difference between tandem unit and booster unit.
    Best regards,
    ravi perumal
    11,025
    Re: Tanem unit and Booster unit
    Nope.
    Tandem or booster of what material ?
    Mar 2007
    INDIA
    42
    31
    I gone through some text books and found the following difference between the tandem unit and booster unit.
    Compressors are in parallel connection is consist of two methods,
    1. Tandem unit
    2. Booster Unit.
    Tandem unit:
    Compressors are connected through common suction and common discharge.
    Booster unit:
    One compressor suction will be other compressor Discharge and other connections are same as per refrigeration cycle.
    I hope you recd some infromation.
    Best regards,
    ravi perumal
