Results 1 to 13 of 13
    gxhphh's Avatar
    gxhphh Guest
    Question Are you interested in mixture refrigerant in cryogenics
    I am researching the mixture refrigerant in cryogenics. It seems to be a promising technology in the temperature range from -200 degree to 25 degree. Do you agree?
    St. Louis, MO
    509
    Re: Are you interested in mixture refrigerant in cryogenics
    The Prof recalls the correct term here is "autocascade" systems. He used to know an engineer at Revco Scientific who blended refrigerants so that he could achieve about a -150°F evaporator temperature on a single stage system.
    Prof Sporlan
    May 2002
    The Netherlands
    48
    274
    It is promisinng, but it relies a lot on 'black magic'. If you blend two refrigerants, pump them through a compressor, separate them and feed them to their respective evaporators, you cannot expect each of them to behave as the pure variant. This makes measuring and finetuning quite hard. Also, a change somewhere affects the entire system.
    Getting these systems to operate over a wide range of environment and load conditions is not easy.
    Dec 2001
    Norway
    13
    Thumbs up Re: Are you interested in mixture refrigerant in cryogenics
    Quote Originally Posted by gxhphh
    yes of course,we are doing som stuff with blend of methan ethan against
    LNG condensation and gas cleaning, have nice day
    JTSTEN's Avatar
    JTSTEN Guest
    You want to know how to do this I can help I have been designing units capable of 4kW @ -120oC with ultimates of -160 oC
    Oct 2003
    5,630
    Jtsten,
    Have you ever used the special scroll compressor of Copeland, designed for use with helium?
    I posted some time ago a link here on RE.
    If you're going as low as -120°C and even lower, is this with an autocascade system or with a conventional cascade setup? I suppose this is then at least a 3 stage cascade (surely for the -160°C application)
    I service 2 autocascade systems from Polycold (US) on a vacuum metalising chamber (capacitor fabrication).
    The first time they called me, I never heard before of an autocascade, I even didn't knew it was an autocascade.
    And I never learned so much at a time on one single machine, in fact basically a simple machine.
    It has 1 compressor of 10 HP, a watercooled condenser and a lot of capillary tubes and coppertubes inside a big foamed cube, 2 relays, and some SV's. That's all. But it cost +/- 35.000 to 40.000 Euros!
    It was magic for me then: we learned in school that this was not possible in a conventional solution, especially in 1 stage. starting at 20°C and going to -100°C.
    May I ask, in what application are these systems used? Medical machines for blood preservation perhaps.
    And do you design/make only such a machines?
    This still remains some sort of magical refrigeration for me. It's going far beyond that of what most of us are doing daily.
    JTSTEN's Avatar
    JTSTEN Guest
    I design these systems under the see s10tech.com principally these competed with the Polycodl systems although they are 20% more efficient. They despite being conceptually simple machines difficult to get to work sucessfully.
    If you are interested in a specific application I would be interested in having an input on the design.
    waternut06's Avatar
    waternut06 Guest
    hi, i am interested to know where i can purchase a phase separator. i am building a autocascade system using mixed refrigerants and i have problems finding a phase separator online. anyone has a clue where to begin? also, i am curious to know besides copeland compressor, which compressor may be suitable for my refrigerant mix?
    jinu117's Avatar
    jinu117 Guest
    Quote Originally Posted by waternut06
    Oil separator should do the trick really. After all all you want to do is separate oil and liquid.
    jinu117's Avatar
    jinu117 Guest
    Quote Originally Posted by jinu117
    --> can't seem to edit... i meant separate gas and liquid... gravity should do trick for it.
    You could make can with copper wool in it for phase separator too. Let the gravity do the work basically.
    Jun 2005
    13
    Scroll or reciprocating compressors of virtually any make will do the job. You need to be sure the compressor will be suitable for the refrigerants (and oil) you intend using though. What temperature are you trying to achieve, I assume this will be below -100 C. ?
    Gonzo's Avatar
    Gonzo Guest
    Quote Originally Posted by jinu117 View Post
    Contact Temprite as they make high efficiency separators for cascade applications.
    May 2006
    china
    98
    Smile Re: Are you interested in mixture refrigerant in cryogenics
    Actually, the "phase seperator" you mentioned is a stuff like "accumulator". And, the reciprocating compressor may be a better choice, there're a lots of previous successful examples.
  1. R600 Refrigerant.
    By tonydeith in forum Refrigerants
    Last Post: 21-04-2011, 08:52 AM
  2. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  3. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  4. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
  5. Refrigerant Mixture
    By Sanjyot in forum Refrigerants
    Last Post: 04-12-2001, 02:24 AM
