Thread: Absorbtion refrigerator
23-05-2002, 04:40 PM #1
I want to fit a small absorbtion refrigerator In a caravan (running off butane gas.) The problem I have is the aluminium exhaust is not long enough to reach outside chimney fitting and needs extending. My question is: can I use copper pipe for the exhaust or would the fumes from the butane gas flame react with the copper?
The manufacturers want an arm and a leg for the extended/ shaped exhaust I require, and no-one local can supply.
I have the same size copper pipe to hand but was worried It may not be safe to use. Can anyone confirm it would be ok or unsafe to use copper for the exhaust?
Thanks.Last edited by explorer; 23-05-2002 at 10:01 PM.
23-05-2002, 10:58 PM #2
Why not try your copper pipe for a while, and then examine it for chemical reaction?
23-05-2002, 11:01 PM #3
Explorer, this question really relates to gas safety but I will pose a couple of replies....
Is this gas fridge a new model or an old one ?
If it is one of the new balanced flue gas fridge that have been developed for the inland waterways BSC scheme then make sure that you use two tubes.
I would also ask whether you are LPG corgi registered to fit this fridge safely (I am not inferring that you are unsafe ).Brian - Newton Abbot, Devon, UK
24-05-2002, 08:15 PM #4
Hi, Explorer. Also if you fit this fridge yourself you may run into a difficulty with insurance, either they ask for details of the corgi guy who fitted it, when quoting insurance or if the worst happens they may not pay out on a claim, even an un-related one.
Safer get a corgi resgistered installer in, I had to for my gas hob at home.
Regards. Andy.If you can't fix it leave it that no one else will:rolleyes:
24-05-2002, 10:52 PM #5
Thanks for contris. All noted.
Propane Refrigerator Conversion
By zolar1 in forum RefrigerantsReplies: 26Last Post: 04-02-2007, 04:42 AM -
thermo acoustic refrigerator: problem with stack heating
By jackal in forum Technical DiscussionsReplies: 6Last Post: 04-09-2006, 05:03 PM -
How the refrigerator is less humid than outside
By Abu Bakar in forum FundamentalsReplies: 0Last Post: 19-06-2003, 03:06 AM -
Absorbtion refrigerator.
By explorer in forum Technical SpeculationsReplies: 1Last Post: 23-05-2002, 04:38 PM -
Outside Operating Temperature for a refrigerator
By Kato in forum Technical SpeculationsReplies: 5Last Post: 10-11-2001, 01:55 PM
