    explorer's Avatar
    explorer Guest
    Question Absorbtion refrigerator
    I want to fit a small absorbtion refrigerator In a caravan (running off butane gas.) The problem I have is the aluminium exhaust is not long enough to reach outside chimney fitting and needs extending. My question is: can I use copper pipe for the exhaust or would the fumes from the butane gas flame react with the copper?
    The manufacturers want an arm and a leg for the extended/ shaped exhaust I require, and no-one local can supply.
    I have the same size copper pipe to hand but was worried It may not be safe to use. Can anyone confirm it would be ok or unsafe to use copper for the exhaust?
    Thanks.
    Bill Nelson's Avatar
    Bill Nelson Guest
    Why not try your copper pipe for a while, and then examine it for chemical reaction?
    Explorer, this question really relates to gas safety but I will pose a couple of replies....
    Is this gas fridge a new model or an old one ?
    If it is one of the new balanced flue gas fridge that have been developed for the inland waterways BSC scheme then make sure that you use two tubes.
    I would also ask whether you are LPG corgi registered to fit this fridge safely (I am not inferring that you are unsafe ).
    Jun 2001
    N.Ireland
    1,630
    Hi, Explorer. Also if you fit this fridge yourself you may run into a difficulty with insurance, either they ask for details of the corgi guy who fitted it, when quoting insurance or if the worst happens they may not pay out on a claim, even an un-related one.
    Safer get a corgi resgistered installer in, I had to for my gas hob at home.
    Regards. Andy.
    explorer's Avatar
    explorer Guest
    Thanks for contris. All noted.
  1. Propane Refrigerator Conversion
    By zolar1 in forum Refrigerants
    Last Post: 04-02-2007, 03:42 AM
  2. thermo acoustic refrigerator: problem with stack heating
    By jackal in forum Technical Discussions
    Last Post: 04-09-2006, 05:03 PM
  3. How the refrigerator is less humid than outside
    By Abu Bakar in forum Fundamentals
    Last Post: 19-06-2003, 03:06 AM
  4. Absorbtion refrigerator.
    By explorer in forum Technical Speculations
    Last Post: 23-05-2002, 04:38 PM
  5. Outside Operating Temperature for a refrigerator
    By Kato in forum Technical Speculations
    Last Post: 10-11-2001, 12:55 PM
