Thread: prosab II Panel
12-03-2007, 12:25 PM #1
prosab II Panel
I have problem in prosab Panel with Sabroe screw compressor . We see error on screen (brine low temp. ) and the compressor does'nt run
asking help Thanks
12-03-2007, 01:21 PM #2
Re: prosab II Panel
Not had experiance on that one but I would check the heater, the stat and trips or fuses.
Paula
12-03-2007, 01:25 PM #3
Re: prosab II Panel
Hi.
It seems that you have a broken PT100 sensor or that the connection/cabel is damaged.
Is the Brinetemp showing fx.-200.
HGS
14-03-2007, 01:41 PM #4
Re: prosab II Panel
Dears / Paulajayne and HGS
Thanks for your interested and I'll Check all connection for all sensors
Can you explain what is Brine temp?
I know the Brine is Ca cl2 solution
regards
15-03-2007, 01:19 PM #5
Re: prosab II Panel
I think a translation problem here.
"TEMP" is short for "Temperature"
Paula
