Thread: STAL SRM SCREW compressor
07-03-2007, 01:49 PM #1
Hello guys just wondering if someone can point me in the right direction as to finding out where i can get some info on parts availability and manual for a type S51E 26A STAL sRM screw compressor as i am having some difficulty in finding some to help with parts and a manual>by the way i am in Australia.She is a bit tired and needing some TLC. Regards Graeme
07-03-2007, 03:57 PM #2
Re: STAL SRM SCREW compressor
I have a couple of US companys that deal with the Stahls,http://mmrefrigeration.com/
07-03-2007, 07:36 PM #3
Hi, Graeme Ellis
Check this page:
https://www.refparts.york.com/ALLPar...aspx?40=PVBYBD
What kind of problem you have with your compressor?
Best regards, Josip
07-03-2007, 11:45 PM #4
Hello,
Yes, same than Josip,
I can find spare parts for that if you want, I can give you my email.
Be carefull, you also need some tools for that type of compressor.
11-03-2007, 03:44 PM #5
g day mate. Cu at work monday.
13-03-2007, 04:20 AM #6
Basically the compressor needs a rebuild due to being very worn internally.Wear metals in oil suggests main bearings and rotors being badly worn. Oil filters are ok and oil pump has been rebuilt so basically it is internal clearances in compressor.56000 hrs on compressor.
13-03-2007, 04:23 AM #7
15-03-2007, 02:01 AM #8
Hi Graeme
Parts and manuals shouldn't be a problem for you in Oz - I'm in NZ. Stal is part of Johnson Controls (who bought York, who bought Sabroe, who bought Stal). I can get pretty much anything for the S20s, though if your rotors are worn you should be able to get them built up by a decent precision engineering shop. The York Refparts website is a bit thin on information and is not the easiest thing to use. I and some others here were with Stal in the UK for a few years and between us have done plenty of overhauls on pretty much all the Stal range.
Drop me a line at if you want some details.Last edited by Andy; 17-03-2007 at 03:07 PM. Reason: No emails guys please us PM system
