    alejo78's Avatar
    alejo78 Guest
    Piston,rotative,scroll...which technology??
    Hi everybody...
    I am trying to understand wich is the best technology for every range of appliance...
    I know that piston technology is cheap and reliable for low power appliances and scroll technology is good for medium to high power uses, but what would you call exactly low, medium and high power?
    Thanks to all!
    Mar 2007
    INDIA
    42
    31
    Re: Piston,rotative,scroll...which technology??
    Low power - Low Bach pressure application
    Medium - Medium Back pressure application
    High - High Back Pressure application
    According to the Back pressure to the compressor the classification as made.
    Best regards,
    ravi perumal
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, alejo78
    Welcome to RE.
    Quote Originally Posted by alejo78
    Hi everybody...
    Thanks to all!
    What you mean here with power
    refrigeration capacity -low, medium, high
    evaporating temperature -low,medium,high
    Hi, Raviperumal
    Quote Originally Posted by raviperumal View Post
    Best regards,
    ravi perumal
    Very interesting, this is an engineering forum can you put some numbers to explain classification of power
    Sorry I do not understand your explanation.
    Best regards, Josip
    alejo78's Avatar
    alejo78 Guest
    Hi to all...and thanks for your answers...
    Perhaps it was not so clear, I was talking about compressors for refrigerating systems...
    What I know is that piston (reciprocal) compressors are used for air cooling appliances until 17000m3/h...
    and that scroll compressors are used only when there is involved a big amount of cooled air (big industrial uses)...but in the middle there is the rotary compressor, or roller compressor, that works in lower mass rates...can you help?
    Thanks to alle!
    Feb 2007
    55
    It really depends on the application.You then have to look at cost and energy efficiency.Other thing that come to mind are hermetically sealed or semi this will affect leak testing when F gas comes to pass.On larger chillers we used to use recips for heatpumps because you couldn't get the correct VI with a screw and that hit the COP.Also trend has a big part to play it is 'uncool'to have recips and cool to have screws or scrolls,even though you can service and repair a recip but generally have to completely replace a srew or scroll.
