Thread: Lubrication oil
    km200099's Avatar
    km200099 Guest
    Lubrication oil
    does anyone know what is the difference between the lubrication oil of PAO 68 (York ) and Mobil SHC226 E ?
    11,025
    Re: Lubrication oil
    Found these links for details of the oils
    PAO 68
    http://www.fammllc.com/famm/lubrican...onOilLowTemp68
    and Mobil
    http://www.kw-oil.com/lubesearch.asp?CatID=3
    Hope this helps
    and welcome to the forum.
    495
    21
    Re: Lubrication oil
    Hello Km Mobiles Shc226e Oil Is Synthetic Oil And It Is Good For Low Temperatures And Especially With Open Type Compressors Because It Is Very Thick And Stops Seals Leaking
    km200099's Avatar
    km200099 Guest
    Re: Lubrication oil
    thank you all for the quick reply.
    I am still trying to understand what is the difference in properties between PAO 68 (York ) and Mobil SHC226 E
    I only manage to find the data sheet for the SHC 226E>
    Any hint to differentiate it?
    Currently the York Chiller SAB163HR is using Sabroe PAO 68 compressor oil but my supplier recommend me to use Mobil Gargoyle Arctic SHC 226E.
    malaysia
    159
    Re: Lubrication oil
    Quote Originally Posted by km200099 View Post
    hola, i've just posted similar question to yours.
    my evaluation of any lueb oil goes towards
    1] viscosity in cSt @ +40degC & +100degC;
    2] pour point;
    3] flash point;
    4] floc point;
    5] wax discomposition;
    6] temperature-viscosity index
    there are some others which the lube oil company would not review ... i do know why.
    hope that helps you.
