    richardG's Avatar
    richardG Guest
    Help with fault on Daewoo ERF 334.M.LC Fridge Freezer
    Hi there all!
    Any advice please would be appreciated.
    fridge compartment on an upright Daewoo Fridge Freezer is not chilling. Fridge bulb lights.
    Freezer chills but is on all the time!
    Unit is in a kitchen which is obviously hot sometimes
    but cool when not in use!
    Am I right in thinking that it is not the stat and that it is as drastic and terminal as loss of refrigerant??
    Or is it something alot simpler??
    I admit to not being a Refrigeration Engineer
    But have a keen interest instilled from my RAF days
    as a General Technician working with Aircraft air cooling trolleys and ***** 12 systems would you believe!!
    Regards Richard
    Mar 2006
    belfast
    239
    Re: Help with fault on Daewoo ERF 334.M.LC Fridge Freezer
    is it a frost free?
    richardG's Avatar
    richardG Guest
    Thumbs up Re: Help with fault on Daewoo ERF 334.M.LC Fridge Freezer
    Yes it is m8!
    It's a NOFROST
    Actually I,ve stripped out the Freezer Compartment
    back panels and found the evaporator coils to be
    seriously iced up and blocking the ducting opening which leads to the Fridge Compartment.
    Have defrosted and all appears OK!
    Suspect my problems could have started when we had a lenghty power cut during the recent storms!!
    But don't fully understand why!
    Thanx for your response though!!
    11,025
    Could be that you had a partial defrost which then refroze in and around the air duct.
    Mar 2006
    belfast
    239
    frost frees usaly tend to do this every so often
