Results 1 to 16 of 16
Thread: Capillary selection software
09-02-2007, 09:13 PM #1
This was several times a question: how to calculate capillary tubes.
Look once on the Danfoss site http://www.danfoss.com/Denmark/Busin...ils/DanCap.htm
English and IP and SI unitsLast edited by Peter_1; 14-02-2009 at 09:33 AM.
10-02-2007, 12:34 AM #2
Re: Capillary selection software
Good one Peter and for those wanting english try here..
http://www.danfoss.com/United_Kingdo...ils/DanCap.htmBrian - Newton Abbot, Devon, UK
13-06-2007, 04:07 AM #3
thank you Peter and Brian
13-06-2007, 07:01 PM #4
good find mate!
14-06-2007, 10:24 AM #5
Thank you so much Peter and Brian for wonderful link and software.
14-01-2009, 08:41 PM #6
Hi All
I have water chiller system that im resiting, the water tank is now going to be outside of the enclosure so i need to extend my pipe run which involves lengthening the cap tube coming off the TEV and back into the suction line. The cap tube is connected to the TEV via a flared end and nut fitting, but im not sure if i need a specialist piece of pipe or how the cap tube enters the suction line. Also what determines the length of cap tube?
14-01-2009, 09:09 PM #7
14-01-2009, 09:36 PM #8
15-01-2009, 02:52 AM #9
Thanks guys good work..
dsp
15-01-2009, 07:56 AM #10
Hey Brian, Iceman, sorry for the topic change, but thank you for your advice. So am i right in thinking there is nothing that determines the length of the equalizer tube?
15-01-2009, 06:44 PM #11
thanks very nice software
regards
gulshan kumar
17-01-2009, 04:47 PM #12
TECUMSEH have a program too
cap_tube_english.zip
search "aplications software"
xxxx:/xxx.tecumseh.com.br/
13-02-2009, 02:02 PM #13
There has to be some sort of mathematical equation to calculate this. If anyone knows of such, would you please point me in the right direction?
Thanks!
14-02-2009, 07:41 AM #14
14-02-2009, 09:42 AM #15
19-02-2009, 08:47 AM #16
