    Apr 2006
    US
    10
    furnace troubles
    I have a 75,000 btu input Arco Air gas furnace that was converted to LP gas when it was installed in 2000 that wasn't working properly. I went out on the call and only one of the burners would light. I noticed that the three burners were all carboned up. I cleaned the burners and the thing lit all three of them. As it ran the flames would occassionally creep back into the burner assembly. But it wasn't really a lazy flame like a venting problem. It would just creep back into the mixing chamber periodically. I checked the gas pressures inlet and outlet of the gas valve both were good. ( 12 in wc inlet and 10 in wc outlet). I disconnected the vent pipe but it did not mater. I am suspecting maybe a small crack in the heat exchanger just enough to effect the draw of combustion gas into the heat exchanger but I am not sure. I was hoping that you guys might offer some insight.
    Oct 2003
    5,630
    34
    Re: furnace troubles
    I don't think that you will see replies to a post of burners in a refrigeration forum.
    Jan 2007
    SPAIN
    172
    Check out h__p://___.hvac-talk.com/vbb/
    on your side of the water... plenty to read there.
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    I can't comment on the equipment that you are working on as we don't have this make of kit, but if any of the burners are carboned up, the you have a serious ventilation problem that needs to be sorted out, the air supply is not enough for the furnace input
    Karl
    Apr 2006
    US
    10
    Thanks for the info Karl. I talked with the manufacturer and they thought that I should replace the gas valve. They stated that moisture could settle in the valve and small particles of water would enter the mixing chamber and cause a sputter and allow the flame to enter the chambers causing the black soot. But I think you are correct about the combustion air lacking causing the black soot because air would be lacking in the chambers. Thanks again for the help.
    Apr 2006
    US
    10
    Quote Originally Posted by momo View Post
    Thanks for the info. I will check it out.
