Results 1 to 1 of 1
Thread: Hotpoint FFS70 Defrost indicator
23-01-2007, 03:21 PM #1
Had problem where the evaporator completely iced up including the drain hole and restricted the airflow causing the "freezer high temp" indicator to light. Have deforsted the unit and it appears to be working, makes ice cubes and froze the sausages but I can't reset the defrost indicator by pushng the button as per the user guide. Any ideas what may be the problem with the indicator but mainly "what caused it to ice in the first instance?"
Ray D
