Results 1 to 2 of 2
Thread: Heater info needed Vilter 440VMC
14-01-2007, 06:12 PM #1
I need to replace the block heaters on my Vilter 440 VMC 4 cylinder ammonia compressors.
I sourced a Vulcan model through Grainger, 1000 watt thermostatic control 100 thru 190 degrees farenhiet.
Can anyone tell me the thread size on the cover where the unit screws in?
Is the Vulcan unit mentioned above a viable replacement?
The boat is at sea and I would like to order this part asap.
The ammonia system is on a fishing vessel to chill salt water, I have three Vilter 440vmc compressors ammonia system, two chillers with two water condensors. I am in the north atlantic in winter and the pump room ambient temperature can get very cold, down around freezing at times.
any help appreciated!
Thanks,
Vin
14-01-2007, 08:09 PM #2
Re: Heater info needed Vilter 440VMC
Welcome to the Forum Sun Dragon!
I do not know the thread size for the Vilter Heater.
We get ours from a Supplier in California who does a lot of Vilter parts sales.
I would be cautious purchasing a replacement unless you have a exact part number. The Oil Heaters are in Direct contact with the oil inside a Vilter. Any copper or brass parts would eventually fail.
I am sure some here can point you to a local supplier.
