Thread: Charging 134a
13-04-2002, 08:55 PM #1
Charging 134a
My Dear experts :
There are some constant coefficients to define the refrigerant charge of typical R & AC
system which operates on R12 , R22 or similar .
but I seriously want to know a common rule of estimating mass charge of the other
refrigerants versus cycle , tonnage and inside volume of systems .
For Exp :
I have recently designed and installed a splite air conditioning system on typical passanger
car with followiong specification :
Compressor : 2pieces 4P15.2 (Bitzer)
Refrigerant :134a
Era.Temp : 45*F (Dx)
Cond.Temp : 65*F (Air cool)
Ambient Temp : 50*F
Total System Volume :120 lit
Reciever Volume : 10 lit
How weigh of R13 should I prepare as a charge ?
What is the physical property of result of oil (Ester BSE55) with air or moisture .
S.P
02-06-2002, 03:08 PM #2
This sounds like a more detailed repeat of your previous post.
If you have an expansion valve, install a liquid line sight glass and charge just enough refrigerant to clear the sight glass of bubbles.
How can a system for a passenger car have a volume of 120 Liters?
If the ambient temperature is 50 F., why do you need A/C ?
Ester oil should not be exposed to moisture or air. If it has been, it should be changed.
Good luck!
410a charging
By gwilliamson in forum Air ConditioningReplies: 39Last Post: 17-11-2010, 05:03 AM -
134A reach in cooler problem
By bvis in forum Trouble ShootingReplies: 11Last Post: 16-03-2009, 02:36 AM -
134a surge drum sizing
By Camille in forum RefrigerantsReplies: 0Last Post: 03-03-2006, 01:44 PM -
Car a/c charging chart
By chilly in forum TransportReplies: 7Last Post: 07-09-2005, 08:18 AM -
System charging
By Dylan in forum FundamentalsReplies: 10Last Post: 17-12-2004, 10:37 PM
