Results 1 to 10 of 10
Thread: Vacuum pumps
02-01-2007, 06:47 PM #1
Vacuum pumps
What type of vac pumps are you guys using and what do you think is the best? My old pump is on its last legs and needs replacing asap. In the past I have used yellow jacket pumps and found them really good . As I work for myself now I've gotta pay for it, so it needs to be good. Any thoughts appreciated
Andy
02-01-2007, 07:02 PM #2
Re: Vacuum pumps
i swear by my javac shark vac pump andy but be intrested to what everyone else thinks
Paul
"KEEP IT COOL"
03-01-2007, 08:30 PM #3
Re: Vacuum pumps
Ive got a yellow jacket one and am happy with it.
Cheers Jon
04-01-2007, 11:45 AM #4
Re: Vacuum pumps
I have the Yellow Jacket as well, with the vacuum tree and two 3/8ths to 1/4 inch hoses and two valve core removers. Definitely makes in cutting down on vacuum times with the larger hoses and valve cores removed.
12-01-2007, 06:07 PM #5
Re: Vacuum pumps
I only use Robinair these days, my current pump is 8 years old and replaced and old Robinair that only had a leaking shaft seal, just as important as the pump is a good torr gauge in torr or mbar.
14-01-2007, 11:35 AM #6
Re: Vacuum pumps
yellow jacket for me too, got good after sales service on them with a loan unit if needed, that may not apply everwhere though.
15-01-2007, 08:21 PM #7
Re: Vacuum pumps
I have found Robinairs to be reliable and reasonably priced.Like MechAcc I use 3/8ths hoses whenever possible.
03-03-2007, 09:19 PM #8
Re: Vacuum pumps
edwards 12, weighs a ton, but is the rolls royce to the ford mondeo robinair,javac,ite...etc you gets what you pay for!
04-03-2007, 09:33 PM #9
Re: Vacuum pumps
hi there
i use a robinair pump myself, they can be a bit dear but well worth it.....
04-03-2007, 10:24 PM #10
Re: Vacuum pumps
Thanks for the replys guys . I ended up getting a Yellow jacket 4cfm and very pleased with it.
