    ARQUITEKNO's Avatar
    ARQUITEKNO Guest
    Red face About IMO pump from Vilter oil pump
    Hello:
    Somebody knows where you can get the oil pump IMO, for the compressors Howden used by Vilter company.
    A special greeting.-
    and happy year 2007
    Aug 2005
    5,327
    Re: About IMO pump from Vilter oil pump
    I'm not sure how this was posted in the supermarket forum, so I will ask the Moderator to move it into the Industrial forums.
    The IMO pump used by Vilter on the VRS twin screw packages is a screw pump. You can contact Vilter for replacement parts... http://www.vilter.com/partsquotes.html
    Mar 2006
    dallas, texas
    69
    108
    13
    ARQUITEKNO
    It has been a year or so but I replaced an imo with a Viking pump on a Howden compressor unit. Just a bit of repiping is all that was required.
    Everything worked great, just size it to the flow and pressure required. It should not be a big deal to use another brand as long as the requirements are similar.
    Howden is a pretty forgiving machine..
    best to you in the this new year.
    Bruce
    ARQUITEKNO's Avatar
    ARQUITEKNO Guest
    Smile Re: About IMO pump from Vilter oil pump
    Dear Bruce:
    Thanks for the information that you give me, was very important, thanks to that I can begin a new search.
    Claudio from argentina.-
