Results 1 to 1 of 1
26-04-2024, 10:10 PM #1
Daikin room thermostat extension sensor
I want to fit a Daikin extended room sensor model KRCS01-4 to a ceiling void unit model FXSQ32M7V1B as the wall mount controller a BRC1D52 sensor is not controlling properly.Heat and
cool modes work ok but on code 41 the thermostat is reading 4 degree different from my probe so its either too hot or cold.
Does anyone know if dip switches on the ceiling void unit have to be changed and if so which ones
to stop reading the temp from the BRC1D52 controller.
