Results 1 to 26 of 26
    Jun 2004
    Wirral UK
    58
    68
    Question Should we oil 410a Flare nuts
    I was asked by one of our technicians the other day, should he oil the face of a R410a VRF flare nut? I said |I was sure he should he then asked what oil should be used? I said I had always used zoom spout high quality turbine oil in the past, but I am not sure if this is the correct stuff to use on R 410A, particularly and something as expensive and a R410a VRF system. Can someone please tell me should we still oil flares and what oil is recomended?
    "It's better to remain silent and be thought a fool than open ones mouth and remove all doubt"
    Apr 2006
    41
    1,620
    23
    Re: Should we oil 410a Flare nuts
    Just use an oil compatible with the system? For doing R-134a systems I just use the left over drops from the container to lub the nuts.
    Apr 2006
    stafford
    42
    974
    can vac oil not be used???
    Paul
    "KEEP IT COOL"
    11,025
    Nope, it is not for use with refrigerants.
    Oct 2001
    Nottingham UK
    5,668
    I don't use oil. I use Leak Lock on each and every R410a flare and to date, I've never had any problems or leaks.
    LRAC's Avatar
    LRAC is offline Veteran Poster I am starting to push the Mods: of RE
    Sep 2006
    Midlands
    453
    Hi frank
    i'm not built like a brick s**t house, how am i going to undo your joints in the future.
    Kind regards
    LRAC
    Oct 2001
    Nottingham UK
    5,668
    Hi LRAC
    Leak Lock doesn't set and seal hard so that you cant redo a joint. It just makes sure that there are no gaps for fridge gas to leak out of.
    Aug 2005
    5,302
    Before the refrigerant changeover period started I used Leak Lock an all joints too and also never had any problems or leaks.
    I have not worked on any "*****" systems for a long time, but based on my past experience I would agree with Franks comments.
    Apr 2006
    stafford
    42
    974
    is leak lock available from any good wholesaler? have not come accross it in years?
    Paul
    "KEEP IT COOL"
    Aug 2005
    5,302
    Where is Frank when you need him???
    This product is still available here in the US, and Frank said he used it, so I'm assuming he has a source.
    Apr 2006
    stafford
    42
    974
    haha helping people i guess,will make a few phone call tomorrow as hell of a van trip over there,boss with love that fuel card bill!!
    Paul
    "KEEP IT COOL"
    11,025
    Yep, LeakLok from any good wholesaler I would think, NRS, HRP etc.
    Used it, loved it, told others about it, still use it.
    PS Frank opened a tinny I think.....
    Apr 2006
    stafford
    42
    974
    on a different subject brian did you get that dakin inverter checker part number i posted for you?
    Paul
    "KEEP IT COOL"
    Oct 2006
    57
    165
    Quote Originally Posted by Blueboy View Post
    It is generally a good idea to use oil on the flare joints. But you do need to use the right type of oil. R22 systems have mineral based refrigerant oil. R407C and R410A use a synthetic (man made) oil. There are two types of synthetic oils, one is ETHER based and the other is ESTER based. Different manufactures use different oils. Daikin VRV R410A uses Ether oil. Melco use Ester oil I think.
    Check with the manufacture, what type of oil they use in the system.
    Obi Wan
    Oct 2003
    5,630
    34
    I use the same practic as Frank, never oil the flares and allways use LeakLock but only on those flare which become cold (freezing cold) an hot each time the compressor runs.
    So on a TXV, only the low side flare.
    And not the flare of course but the thread of the flare.
    Oct 2001
    Nottingham UK
    5,668
    Leak Lock is available from United Refrigeration, Climate Centre, RPW and others.
    http://www.highsidechem.com/leaklck.html
    11,025
    Quote Originally Posted by superswill View Post
    Yes, thanks, apologies for not saying 'thanks' earlier.
    Jul 2006
    New Zealand
    77
    65
    I have used Loctite 567 thread sealant for a number of years with great success. It contains Teflon. I just put a little on the back of the flare (stops nut grabbing)and a little on the flare face.
    Does not go hard, it cures to a chewing gum consistancy.
  19. #19
    absolute's Avatar
    absolute Guest
    Why use oilatall?
    If the flare is made well,then it will sealdry.
    I never use oil and after pressure testing I never getcall backs.
    I do use a super duper new style flaring kit though.
  20. #20
    Apr 2006
    41
    1,620
    23
    Oil ensures smooth pressure distribution, no matter how new or good the flare if there is no oil or other lubrication the torque is unevenly spread over the surface, thus work hardening will be more sever issue over the life time of the joint.
    Well made flare + Oil = solid life long joint
    Well made flare - Oil or lube = Russion rulet
  21. #21
    Oct 2003
    5,630
    34
    I think I can say I have gathered already some experience over the years.
    I never had a leak due to the fact I never used any oil.
    Why they suggested oil in the older days?
    The cone of most older flares was a smooth, round cone, the type you find often these days in the cheaper kits (with flaring and expanding till 3/4)
    This cone makes the flare by pressing it over the whole surface of teh expanding copper, so a lot of friction.
    The force you apply on the lever while turning on the cone is equal spread all over the flares surface, so the bending force/mm˛ (tension) copper flare is relative small.
    Now the newer flares: they're not any longer smooth surfaces but mostly with 4 edgess on it.
    The same force is now divided over these 4 edges whereby the applied bending force/mm˛ (tension) is now many, many times larger then the smooth cones.
    It doesn't push any longer a flare but you can see it more like rolling the flare, almost cutting it.
    You also needed to remove the sharp edges after cutting the tube before flaring it.
    Well with the four edges with teh big tension, these edges are removed automatically.
    Try this once for yourself with an old one and e new one http://www.yellowjacket.com/prdetail...02&Auto=1#a130 or the off center ones http://www.yellowjacket.com/prdetail...2&Auto=1#a5000
    The off center ones is even an improvement of the above explanation because it applies all the force of your hand over only 1 edge, resulting in very flat, well made flares without removing teh cutting edges and without adding oil.
  22. #22
    Oct 2003
    5,630
    34
    Yelow Ritchie describes it in fact perfect, better then my explanation in my school English.
    Multi-faceted cone rolls a precise flare and simultaneously polishes it on brass, copper, and aluminum
    It polishes the flare indeed very well and removes very well the cutting edges.
  23. #23
    Jun 2007
    sydney
    47
    5
    well ive never used oil or leak lock on 410a and lol have never got a leak,but mmm i mite look into it myself
  24. #24
    Sep 2005
    33
    I got some from Dean & Wood in Leeds when I worked at SIAS
    Frostycold
  25. #25
    Jun 2004
    Wirral UK
    58
    68
    Talking Re: Should we oil 410a Flare nuts
    Well I am afraid to say that my understanding is that a little bit different to those imeadiatley .
    If oil is placed on the flare face it causes a capillary action, that is to a kind of suction seal between the two faces thus actually making the seal. I think that if oil, or something is not applied then the very principle of the flare connection is lost.
    I originally asked the question that started this thread, since then I have bought some flare oil from the US, its great .I have mineral and polyester oil. I have also experimented with leak lock, purchased from NRS in Liverpool off Bernie, and I have found this to be really good too.
    In Summary, a good flare kit, preferably concentric, is essential. Good quality oil, Leak lock, or similar is also essential . Better still braze it if you can!!!!!!
  26. #26
    Nov 2007
    I use leak-lock it works grade and its not messy
