Results 1 to 11 of 11
Thread: R22 alternative
    Dec 2006
    Dublin
    49
    7
    R22 alternative
    Hi guys,
    Just wondering if any of you have heard of RS-52 as an alternative for R22, and if so has there been any joy with it. It is supposed to be a direct replacement and may have been tested on a few DX units. However I would be interested if any of you know if its been used on a flooded system??
    Cheers..Yogi
    Apr 2006
    55
    1,908
    30
    Re: R22 alternative
    hi yogibear
    RS52 is more commonly known over here as R428a and was designed for low/medium temperature refigeration.
    It can be used with mineral/alkylbenzene/polyolester oils
    Running pressure's are similar to R502, a little higher than R22
    chillerman2006
    Dec 2006
    Dublin
    49
    7
    Re: R22 alternative
    Hi Chillerman,
    Thank you for you input. im just concerned about putting it into a flooded system. Reckon i would rather change to 134a, although i will drop effeciency, but there are ways around that..
    Apr 2006
    55
    1,908
    30
    Re: R22 alternative
    Quote Originally Posted by Yogibear View Post
    Hi Chillerman,
    HI Yogi
    i would have thought R407c would be a better option - pressures are higher but like R134a you will need to retrofit the unit
    if you like i can email you a complete list of available gases - there uses - compatible oils etc.
    chillerman
    Apr 2006
    Northern Ireland
    31
    Re: R22 alternative
    Hi Chillerman
    can you email me a complete list of available altenative gases for R22- there uses - compatible oils etc.
    Regards JF
    11,025
    Re: R22 alternative
    I don't know, JF lurks for over 7 months and then doesn't even say 'please'.
    Hi JF, don't be shy now, we appreciate all posters here.
    May 2006
    Brisbane
    71
    48
    Re: R22 alternative
    How about R417a (Isceon 59) I believe it is a drop in replacement for R22
    Aug 2001
    1,046
    Re: R22 alternative
    ...... using an e mail address as a name is asking for spam.......
    Apr 2006
    55
    1,908
    30
    Re: R22 alternative
    Quote Originally Posted by johnf4@mac.com View Post
    Hi Chillerman
    Regards JF
    Hi John
    i have just emailed them to you
    chillerman
    Scotland
    104
    Re: R22 alternative
    Quote Originally Posted by chillerman2006 View Post
    HI Yogi
    chillerman
    Hi all,
    I suspect that the glide of R-407C is too much for a flooded system (about 7 deg C), and I am not aware of any "drop-in" for R-22 that has no glide. However we have done some testing of various ISCEON MO refrigerants in flooded water chillers. If you put ISCEON MO59 into the plant then what circulates is broadly similar to ISCEON MO29, so the performance can be guesstimated using the MO29 data (glide of about 3 deg C). Oil return from the chiller's original rectifier was also fine. I'm not sure that RS-52 would do the same thing so performance might be very poor. As they say in all the best films "There's only one way to find out"!!
    cheers
    Andy P
    Apr 2006
    41
    1,620
    23
    Re: R22 alternative
    R-290? Environmentaly safe and good chararistics!
