Results 1 to 2 of 2
    Nov 2006
    china
    48
    21
    Can I use calcium chloride in propylene system?
    Can I use calcium chloride as secondary refrigerant in propylene system?Does them be compatible?I found in some MSDS such as INTERGAS COMPANY said propylene is react viloently with halogenated compounds.
    Jan 2006
    Croatia
    68
    2,261
    31
    Re: Can I use calcium chloride in propylene system?
    Hi, Joanna
    Welcome to RE
    Quote Originally Posted by joanna View Post
    Tell us something more about your project.
    I believe any good chemist or chemical laboratory can give you much better answer what happens when CaCl2 came into contact with propylene.
    Maybe to change the primary refrigerant or you can use some other secondary refrigerant because calcium chloride is quite aggressive
    Best regards, Josip
