    Pengu's Avatar
    Pengu Guest
    Prestcold compressor spares
    Just working on a Prestcold K100, and found the terminal seal leaking, went to Climate center for new ones and i cant buy them on there own they want to charge me 60 quid for a whole gasket set! Any one else got this problem and knows of where to get them cheaper
    Thanks all you fridgies out there
    Feb 2006
    derbyshire
    610
    Re: Prestcold compressor spares
    its only a "O" ring, go to the nearest reman centre and give them the sob story, should be pence.
    Nov 2006
    63
    392
    Try giving J & E Hall a ring at Derby a ring they will more than likely have one.
    Ian
    Feb 2006
    Try ThermaCom in Nottingham or Reading who will let you have this free of charge. 0118 950 0606
    The O ring you require is BS 128 suggest you use Nitrile, and this can be bought for a few pence from any good bearing stockist - Bearing Traders; BSL; even RS (may be a few quid there !).
    veer789's Avatar
    veer789 Guest
    hi,i bought a condensing unit,prestcold model p32150x/a0138-45.and my condenser have many leakeage so i would like to by a new one and i dont know where to look for it,pleased help me;
